With the help of automations, you no longer have to manually add rows with certain entries to your tables, but can have these steps performed automatically. To do this, simply define an appropriate automation for any table view.
Add entries via automation
  1. In the base header, click and then click Automation Rules.
  2. Click Add Rule.
  3. Name the automation and specify the table and view in which it should act.
  4. Define a trigger event that triggers the automation.
  5. Click Add Action and select Addrow as the automated action.
  6. Confirm with Submit.
First define a trigger event for the automation.
Trigger events basically available for selection
