No-code platforms enable the departments in your company to build digital applications themselves, without relying on classic software development for every project. Without a binding structure, however, this freedom can quickly lead to shadow IT, security gaps and compliance risks. Well-thought-out no-code governance therefore creates a framework in which your employees can work independently while sensitive data, access rights and critical processes remain protected.
What does no-code governance mean in a company? #
No-code governance refers to the organizational and technical rules with which you manage the use of no-code platforms in your company. You define which platforms are approved, how applications are developed and released, and which security requirements apply. The goal is to allow your departments to work independently while ensuring that applications are used in a controlled and traceable way.
You need to bring several areas together. With IT governance, you create the overarching framework for the use of your IT systems. IT security protects data, applications and infrastructure. Through IT compliance, you ensure that you meet internal and external requirements. Data governance also plays an important role when you define how your employees may store, use and share data.
Why a lack of no-code governance becomes a security risk #
No-code makes the development of applications much more accessible. But this is exactly where the risk lies. Where employees can set up digital solutions independently of IT, structures quickly emerge that the company can hardly oversee completely.
Shadow IT and a lack of transparency #
When a department urgently needs a solution for a new process, a quickly set-up tool seems practical at first. However, if more and more teams use applications on their own and store sensitive data in them, you quickly lose oversight.
It then becomes hard for your IT to tell which platforms are in use, where information is stored and who is responsible for individual applications. This creates not only shadow IT, but often also data silos, because information is spread across different systems.
With effective no-code governance, you create transparency about the platforms and applications in use. A central directory helps you record existing solutions and identify uncontrolled individual solutions at an early stage.
Security risks from access and integrations #
Even with an approved platform, you significantly influence IT security through access rights. If employees can see or edit more data than they need for their tasks, you unnecessarily increase the risk.
With a rights and roles concept, you define which users may access certain applications and information. The principle of least privilege gives you clear guidance here: you only grant the permissions a user actually needs for their tasks.
As systems become more interconnected, you should also keep an eye on API interfaces and external services. Even an application that is securely configured internally can create risks if it automatically transmits data to third parties. You should therefore firmly integrate cloud security and the control of such connections into your IT security.
Compliance and data protection risks #
Particular care is required when your applications process personal or other sensitive information. You must be able to trace which data is stored, what purpose it serves and which systems it is passed on to.
This is not just about GDPR compliance. Depending on your industry and company structure, you must also consider internal requirements, industry-specific regulations or standards such as ISO 27001. Without proper documentation, this makes IT compliance harder for you, as well as the later analysis of security incidents or faulty changes. You should therefore define when planning an application which data may be processed and which protective measures are required.
The most important building blocks of secure no-code governance #
To scale citizen development securely in your company, you need traceable structures. These should give your employees guidance in their day-to-day work without causing unnecessary administrative effort.
Define roles and responsibilities #
Define who is responsible for developing, reviewing and maintaining your no-code applications. Citizen developers can, for example, create and maintain applications, while business owners assess the functional requirements. Your IT administrators take care of the technical framework. For applications with higher protection needs, you should also involve the responsible people from IT security or IT compliance.
Document the responsibilities for every productive application. This way, your employees know whom to contact about changes, technical problems or security questions.
Also take staff changes into account. When employees leave your company or change departments, responsibility for their applications must pass to someone else. Define a binding handover process so that important applications do not depend on individual employees.
Classify applications by risk #
Not every no-code application places the same demands on your IT security. A simple internal task list needs far less control than an application with which you manage personal customer data or business-critical processes.
You should therefore classify your applications according to their risk and protection needs. Consider, among other things, the type of data processed, the impact of possible errors and the connected systems. On this basis, you determine which security requirements apply and which bodies you involve in the review. This way, you align your controls with the actual risk and deploy your resources where they matter most.
Manage rights and access centrally #
With a well-thought-out rights and roles concept, you prevent employees from gaining access to data they do not need for their tasks. Assign permissions as granularly as possible and review them regularly.
Make sure you do not only define access rights when building an application. Teams change, employees take on new tasks and additional functions extend existing applications. Check regularly whether the rights granted still match the current process. With central access control, you keep an overview and can more easily maintain a consistent level of IT security.
Establish uniform IT security processes #
You do not have to develop security checks from scratch for every application. With standardized IT security processes, you create a fixed procedure for recurring reviews. Depending on the use case, you should consider the following points, among others:
- the review of processed data and its protection needs
- the control of access rights and roles
- the assessment of connected systems and API interfaces
- securing authentication
- secure data storage
- the planning of backups and recovery procedures
To do this, apply your existing IT security policies to the use of no-code applications. Uniform reviews and regular check-ups give your departments guidance and at the same time reduce the coordination effort for your IT security team.
Challenges when introducing no-code governance #
Introducing no-code governance requires more than setting binding rules. Companies must integrate the requirements into existing workflows and make sure the teams involved apply them in everyday work. Several challenges often arise in the process:
- limited staff and time IT resources for reviews and controls
- rapid changes in the no-code platforms in use
- different requirements and ways of working across departments
- lack of acceptance of additional rules
It is particularly important to make the rules understandable and practical. If the requirements are too complicated or involve a lot of effort, your employees become less willing to follow them consistently. In doing so, you encourage exactly the shadow IT you actually want to avoid. You should therefore involve the affected departments early and align the governance processes with their actual workflows.
What governance can look like across the entire application process #
It is best to integrate your governance requirements directly into the entire application process. Do not wait until shortly before an application is released. Define right from the start which requirements apply during development, review, use and later decommissioning.
Step 1: Development
Word your IT security policies so clearly that your employees can see for themselves which requirements apply to their use case. This way, you take security aspects into account directly during development and avoid later corrections.
Step 2: Review and approval
Document the review result and record who approved the application. For changes that significantly affect the risk profile, you should provide for a new review. This keeps it traceable on what basis an application may be used in production.
Step 3: Operation and monitoring
With an audit trail, you can trace relevant activities and more easily follow changes to data or systems. This helps you with internal reviews as well as with analyzing potential problems.
Also check regularly whether access rights, integrations and responsibilities still match the current purpose of use.
Step 4: Archiving and decommissioning
Then remove access rights that are no longer needed and deactivate connected interfaces. Document the decommissioning so that it remains clear when the application was taken out of operation and which measures were taken.
How to resolve the conflict between IT security and agility in your company #
You may worry that additional governance rules will slow down the benefits of citizen development again. If your employees have to go through several approval stages for every small change, you do lose part of the speed that no-code is actually meant to offer. What matters is therefore adjusting the scope of controls to the respective risk.
So create clear room for maneuver for your citizen developers. Set binding standards and enable independent decisions within this framework. Standardized review procedures and clearly defined responsibilities help make coordination more efficient.
What matters is that your IT governance does not centralize every decision, but only provides for additional controls where they are necessary. This way, you combine reliable IT security processes with flexible development processes and enable your departments to implement new solutions quickly.
Implementing no-code governance with SeaTable #
With a central no-code platform like SeaTable, you can also map many of your governance requirements technically. Instead of using different individual solutions in different departments, you bring applications and data together in a shared environment.
In SeaTable, you can assign access rights in a differentiated way and control sharing specifically for different areas and user groups. Depending on the use case, you give employees read-only access or allow them to edit certain data. With table permissions, you can narrow down access even more precisely.
SeaTable also supports you with traceability. Through various histories and logs, you can review changes and activities after the fact. This supports both internal controls and the requirements of your IT compliance and IT security.
Via API interfaces, you can connect SeaTable to existing systems. If you have high requirements for cloud security or data sovereignty, you can also run SeaTable on your own infrastructure. This gives you more control over where your data is stored and how you design your technical environment.
In this way, SeaTable gives you a technical foundation for your citizen development within a centrally managed environment. Which additional reviews and approvals you need is determined by your own IT governance and the respective protection needs.
Conclusion: Give no-code a framework with governance #
With no-code, you give your departments the opportunity to shape digital processes independently. Without suitable structures, however, you risk shadow IT, unclear responsibilities and additional security gaps.
With effective no-code governance, you combine organizational requirements with technical safeguards. You define roles, classify applications by risk, manage access rights and establish uniform IT security processes.
Do not see governance as a rigid set of rules. Platforms, processes and requirements keep evolving. So review your structures regularly and adapt them to new requirements. This way, you can benefit from no-code and keep your IT security in view in the long term.
FAQs on no-code governance #
What is meant by no-code governance in a corporate context?
How does no-code governance prevent shadow IT from emerging?
What influence does no-code governance have on IT security?
Doesn't strict IT governance hold back the innovation of citizen developers?
