Writing texts, summarizing emails, creating images: generative AI has long since arrived in everyday working life. More and more companies are putting artificial intelligence to productive use, automating processes and unlocking new efficiency potential. In the process, AI tools are increasingly evolving from an experimental toy into a business-critical technology.
That is why concerns are growing in many places, as are the requirements regarding data protection, data sovereignty, cost control and IT security. Anyone who transmits sensitive company data, internal documents or source code to external cloud AI services should be clear about where that data ends up, to what extent it is protected and whether it is used to train the models.
When you self-host an AI, on the other hand, you move data processing into your own infrastructure. A local LLM (large language model) can run, for example, on an AI server in your company’s data center. This is how you create the technical basis for digital sovereignty.
  • A high level of data protection: Sensitive data stays within your own server infrastructure and is not transmitted to external AI services.
  • Digital sovereignty: With an open source model, you can train your own AI and act independently of the major AI providers.
  • Full cost control: With a local AI, there are no usage-based token costs, and you are spared price increases from external cloud AI.
  • More flexibility: You decide for yourself which AI model to use, which data to train it with and when to install new versions.
  • Seamless integration: Via API interfaces, the local AI can be connected with databases, applications and automations to form a comprehensive system.
Self-hosting AI
Deciding whether to use cloud AI or to self-host AI is not an easy one. Both approaches have their advantages and disadvantages. Whether self-hosting or cloud AI is preferable depends above all on how much weight you give to certain criteria. So assess how high your requirements really are in terms of digital sovereignty, data protection, compliance, scalability, model size and total costs.
  • Cloud AI services often score with simple, usage-based scaling and a quick setup without any hardware installation. This means you do not have to procure and maintain GPU infrastructure, but use the provider’s AI servers instead. For individual tasks, test phases or highly fluctuating, barely predictable usage, cloud AI can be particularly attractive.
  • Local artificial intelligence on your own AI server, by contrast, offers full control over data processing. You decide for yourself which models to use, which systems they are integrated with and which data they process. With consistently high AI usage and data of high (confidential) value, self-hosting also becomes economically interesting.
Criterion Local AI Cloud AI
Hardware owned by you rented as needed
Data control very high low, depends on the provider
Scalability inflexible, depends on the hardware very flexible and simple
Maintenance effort high low
Costs high acquisition and operating costs ongoing license costs, usually usage-based
Offline operation possible not possible
If you want to self-host an AI, you should not only consider the capabilities of the models. What is decisive is the interplay of hardware, model size and specific business processes. The central question is therefore: how much computing power do you need for your AI processes? Above all, your own AI server needs a GPU, VRAM, SSD storage and cooling. With several parallel users, efficient GPU utilization and network bandwidth are also required.
Graphics processing units (GPUs) form the heart of AI servers today. For LLMs, the GPU’s available VRAM (video random access memory) is particularly relevant. This refers to the local memory of a graphics card, which serves as fast intermediate storage for creating texts, graphics and images.
Self-hosting AI: graphics cards
You do not always have to dig deep into your pockets for graphics cards. Small AI models can in some cases already be run on powerful consumer hardware with up to 12 GB, while larger models require considerably more GPU memory (usually more than 24 GB).
Your own AI server can release a lot of waste heat and have enormous power consumption and throughput. In order to self-host AI, you therefore need not only the components already mentioned, but also special cooling systems, cabling, networks, uninterruptible power supplies and, of course, server rooms to house your own AI server.
Infrastructure for your own AI server
Which AI models are best suited for using an AI locally? That depends mainly on the desired model size, the use case and the available hardware.
7B and 70B stand for the number of parameters of an AI model in billions, with 7 billion parameters corresponding to a small model and 70 billion parameters to a large one. Depending on the use case, a small, fast and inexpensive 7B model or a large, compute-intensive and costly 70B model may be the better choice when you want to self-host AI. The following overview serves as a rough guide:
  • 7B models are ideal for straightforward tasks such as chats and simple automations. They can understand ordinary texts, write summaries or answer simple questions. With complicated logic puzzles or deep specialist knowledge, however, they make mistakes. In return, they need little electricity and computing power and can already run on an ordinary gaming PC.
  • 70B models can solve complex problems, take on more demanding business tasks and discuss difficult topics like an expert. But they take longer to compute and respond and have high VRAM requirements. As a result, they cost significantly more electricity to operate and require expensive professional graphics cards that are normally found in data centers.
Aspect 7B models 70B models
Model size small large
Response speed very fast noticeably slower
Logic simple complex
Hardware requirements relatively low very high
Costs inexpensive expensive
Typical areas of use e.g. simple automation, chatbots e.g. complex analyses and demanding tasks
Self-hosting an AI model
Beyond that, you should pay attention not only to the size of the model, but also to quantization. That is because quantized model variants need considerably less VRAM than full-precision models. Quantization refers to reducing the computational precision of AI models, for example from 32-bit floating-point numbers to 8-bit integers. This involves a trade-off between the speed and the accuracy of the calculations.
Quantization reduces the computational effort and can make large models practicable for local AI systems by increasing the response speed at the same hardware computing power. A sensible strategy when self-hosting AI is to start with a quantized model first. This lets you test what response speed and quality your specific use case demands before you invest in a more powerful GPU infrastructure.
Self-hosting AI: circuit board
If you want to self-host AI, non-commercial open source models in various sizes and with various capabilities are particularly suitable. One very popular model is Llama 3.3, which currently counts as the standard for your own AI server with powerful hardware. Here you can see a comparison of Llama 3.3 from the US corporation Meta with a European model from Mistral and a Chinese alternative from Alibaba. All models are open source and use Q4 quantization, which reduces the memory requirement to roughly a quarter compared to full precision.
Name Provider Size Main area of use VRAM required
Llama 3.3 Meta 70B all-rounder with complex logic 42 to 45 GB
Qwen 2.5 Coder Alibaba 32B programming and data analysis 20 to 24 GB
Mistral Large 2 Mistral 123B business applications and agents 75 to 80 GB
If you want to install an AI locally, you no longer have to develop a complex software architecture today. A few tools can make getting started considerably easier.
Ollama is open source software that enables you to run AI locally. With Ollama, you can download freely available language models directly onto your computer and make them available to a wide range of applications via a standardized interface. One disadvantage is that Ollama does not have a graphical user interface for Linux, which is why it requires prior technical knowledge.
Just like Ollama, vLLM is an open source inference engine for large language models (LLMs). By comparison, however, the setup and the use cases are more demanding. vLLM is designed for high throughput and multiple GPUs and is particularly suitable for your own AI server with many parallel requests. It stands out for making the operation of AI models on your own hardware faster, more efficient and more scalable.
Powerful AI server of your own
Thanks to an easy-to-use desktop app with a graphical user interface, LM Studio scores as a low-threshold alternative to Ollama and vLLM. LM Studio integrates the Hugging Face platform, which provides access to a range of AI models. As soon as you have downloaded and installed a suitable model, you can interact with the chatbot right away. In return, however, LM Studio is also more resource-hungry and not open source.
Another interesting component in case you want to self-host AI is Open Web UI. With this self-hosted AI platform, you can create a user-friendly web interface for AI models that you run locally with Ollama or vLLM, for example. This turns an initially inaccessible local LLM into an application that people without technical expertise can use as well.
Self-hosting AI and using it as a chatbot with a user interface
A typical architecture could look like this, for example:
User → Open Web UI → Ollama or vLLM → local LLM
This way, you can install an AI locally and connect applications via APIs. If you run AI locally, you should also consider monitoring, authentication, permissions, backups and updates from the outset. Starting an LLM on your own AI server is technically only the first step on the way to a secure productive system.
The greatest added value often comes not from the AI itself, but from embedding it in business processes. A local artificial intelligence can, for example, analyze new records from an internal database, classify texts or summarize incoming documents. Via an API interface, the result can then be passed on to a CRM system, for instance, or start an automation.
Thanks to no-code AI – for example with a no-code AI workflow builder – you can model such processes largely without classic programming. This reduces the development effort and makes AI functions accessible to citizen developers in the company. If you self-host both the no-code AI workflow builder and the AI itself, data processing takes place exclusively within your own infrastructure.
At SeaTable, the choice is yours: benefit from the scalability and convenience of the cloud or install SeaTable on premises on your own infrastructure. As an AI no-code platform, SeaTable opens up interesting possibilities for you, such as combining no code, relational databases and AI automations: use powerful functions such as Summarize, OCR, Extract, Classify and Custom Prompts.
SeaTable’s AI automations
SeaTable Cloud uses a Gemma 4 from Google with 4 billion parameters as its AI model. For cloud users, AI automations run on our own AI server in Germany. Your data never leaves this infrastructure at any point and does not flow to Google or other US providers.
For full control, you can self-host not only SeaTable Server, but your AI as well. This way, you can automate workflows without having to transmit sensitive information to an external cloud AI. The SeaTable AI component is based on LiteLLM and therefore supports the connection of a wide range of models – including all LLM services with an OpenAI-compatible API. In our admin manual, you will find the instructions for deploying SeaTable AI and example configurations for numerous popular LLMs.
Would you like to hold a real-time dialog about your database in SeaTable or edit it with individual prompts in natural language? Then an AI agent is exactly the right solution! Behind this approach is the SeaTable MCP server. MCP (Model Context Protocol) is an open standard that enables AI models to interact actively with data sources. This allows the chatbot to access your database in SeaTable directly and answer questions about it – with no detours and no loss of information.
This works best with powerful AI models (e.g. Claude Desktop from Anthropic) that can answer complex questions and work with your data in multiple steps. For data protection reasons, it is important to understand that you are granting the AI agent access to the data in your SeaTable base. You control the AI agent’s permissions via the API token that you generate in SeaTable. If you self-host an AI, you can install both SeaTable and the MCP server on your own infrastructure and connect them with the local AI (via Ollama or LM Studio, for example). That way, your data never leaves your system at any point. You can find more information on this here.
When you host your own AI, you decide on the AI model yourself, operate your own AI server and retain full control over your data. This is particularly interesting for companies with high data protection requirements and for the public sector. However, anyone who wants to self-host AI should plan the infrastructure realistically: GPU and VRAM largely determine the possible model size, while quantization can optimize the speed.
With the right architecture and open source software such as Ollama or vLLM, AI can be run locally and integrated into existing company processes via APIs. No-code AI tools like SeaTable, meanwhile, enable you to automate your workflows efficiently and to analyze and edit your no-code databases with AI agents, without having to transmit sensitive business data to an external cloud AI.
What is the biggest advantage of hosting your own AI?
The most important advantage is data sovereignty. If you self-host both your existing system and the AI, your data never leaves your own infrastructure. This enables an architecture geared towards a high level of data protection and digital sovereignty.
What hardware do I need for my own AI server?
That depends mainly on the AI model you want. Small 7B models are significantly cheaper to operate than 70B models. The GPU and VRAM are particularly decisive. In addition, you need sufficient SSD storage and suitable physical infrastructure (e.g. cooling systems). Quantization can, however, reduce the hardware requirements of many models.
How does the performance of local AI differ from commercial cloud AI?
In principle, AI models on your own AI server can achieve the same performance as in the cloud. Commercial cloud AI services, however, often have their own data centers with very large GPU clusters and can therefore provide incredibly powerful models and scale more or less at will. Local artificial intelligence, on the other hand, cannot scale flexibly and needs correspondingly powerful hardware to achieve good speed under heavy load.
Can I connect a local AI with no-code tools and automations?
Yes. Via API interfaces, you can connect a locally running LLM with no-code AI tools such as SeaTable, which lets you create your own databases, applications and automations without any programming knowledge. This means you can, for example, have texts summarized, records classified or documents read out, and then automatically trigger further follow-up actions.
Which open source models are suitable for running an AI locally?
That depends on the use case and the available hardware. Like all LLMs, open source models come in different sizes and with different capabilities. Llama 3.3, for example, is a well-known 70B model from Meta that is suitable for complex standard tasks and requires around 42 to 45 GB of VRAM. European alternatives are available from Mistral.
TAGS: Digital Transformation IT Security & Data Privacy Integrations & Automations
