You have organized your information in a base, table or view and want to share it with others or collaborate on it? In SeaTable this is done easily and quickly with a share. This way you can grant access to your data to a single user, a group or external people.
In this explanation and overview article, you will learn about the sharing options available in SeaTable and everything you need to know to use them efficiently for collaboration with others.
Permissions for shares
In SeaTable, you have the ability to give specific people or groups access to bases, Tables, and Views to work collaboratively with the data. While this has many benefits for teamwork, there may be confidential information that you don’t want everyone on the team to have access to.
That’s why SeaTable allows you to define tiered permissions on each share. By specifying whether it should be a read-only share, a read-and-write share, or a custom share , you retain full control over who is authorized to do what in your base, table, or view. Of course, this means you also have the ability to change and revoke permissions.
Functionality and types of shares
With a share you grant access to a base, table or view to other persons. The authorized users will see the share as a separate base on the home page, and the sharing user will also be mentioned. Depending on the type of share, other users can only view or also edit your data.
Sharing can be done on the level of a base or a view. If you share a view, then the authorized user will have access only to the data in this view. The rows and columns that are hidden by the view settings, as well as other tables in the base, remain hidden from the user.
Each share - whether for a base, table or view - is assigned a permission level. The two basic permissions are read-only sharing and read-write sharing.
- Sharing with read permissions: Read permissions allow users to view tables and data and change view settings such as filters and groupings. However, users cannot make changes to tables and data with this permission.
- Share with read and write permissions: With read and write sharing, users can make changes to tables and data, but they cannot install plugins or share the base or view with other people or groups.
To give you even more options when sharing a base than you have with the two basic permissions, SeaTable also offers custom sharing permissions on bases. With a custom share permission, you can share multiple tables and views with different permission levels in a base in one fell swoop.
Each share, regardless of the assigned authorization, can be terminated at any time by the owner or an administrator.
Sharing options for bases
The share of a base can be made to different groups of persons:
- Share a base with a user
- Share a base with a group
- Share via invitation link
- Share via external link
Sharing to a user or group lets you share the base within your team. Sharing by invitation link allows you to give access to a base to people outside your team (but inside SeaTable). External link lets you share bases or views externally, whether someone has a SeaTable account or not.
All these shares are done via the Share dialog - a window that you can reach via the Share icon in the base options or via the SeaTable home page. There, move the mouse cursor to the base you want to share and click on the three dots that appear on the right. Then open the share dialog by clicking on Share.
Manage base shares
Managing your base shares is done in the same way as creating them via the Share dialog. There, the existing shares or links are displayed under the respective share options.
An existing share to a user or group can be extended or restricted at any time by changing the share permission. To do this, click on the pencil icon . A share can be terminated or a link deleted by clicking on the x symbol. All changes are effective immediately. For an existing link, the password protection, the expiration date and the URL cannot be changed.
You can also get a comprehensive overview of all shares and links to a base under Bases in team administration , if you are a team administrator.
Shares for tables
If you don’t want to share an entire base, but only individual tables , that is of course also possible. Custom sharing allows you to share multiple tables and views at once and send them to team members or entire groups.
Shares for views
You create the share of a view in the opened table. When you are in the view you want to share, click the Share icon in the view options. Do not confuse this with the Share icon of base.
You will then be taken to the familiar Share dialog, where you can create your view shares in the same way as for the bases. A view can be shared with three groups of people:
As soon as you click the Submit button for a share option, the selected person or group can access the view with the granted permission. To share a view with multiple users or groups, repeat this process.
As with bases, you can create an external link to share the view publicly. The shared view is always displayed as a base on the home page for authorized users.
