You can delete both external links and invitation links at any time in two different ways. Please note what consequences the deletion has for access to your data.
Click the share icon in your table
  1. Open a base or view for which you want to delete a link.
  2. Click the Share icon  for bases or views.
  3. Depending on which type of link you want to delete, click either Invitation Link or External Link.
  4. Hover your mouse over the link and click the x icon.
Delete external links and invitation links
  1. Switch to the SeaTable home page and click on your avatar image.
Access to the team administration
  1. Open the team administration of your account.
  2. Click Bases in the navigation.
  3. Depending on which type of link you want to delete, click either Invitation Links or External Links.
  4. Select the link you want to delete.
  5. Confirm the deletion by activating the toggle and click on Delete invitation link (for invitation links) or Delete share (for external links).
The deletion of an invitation link has the following consequences:
If users try to open a deleted invitation link, the following error message appears.
Error message when opening deleted invitation links
Consequently, after deleting the invitation link, no other users can get access to the shared base.
The deletion of an external link has the following consequences:
If users try to open a deleted external link, the following error message appears.
Error message when deleting an external link
Consequently, after deleting an external link, all users lose access to the data. Even web pages in which you have embedded a view via an external link can no longer display the data.
