Available with Enterprise
To check the correct execution of an automation, you have the possibility to view the execution log. In this log, SeaTable records the following information for each automation run: execution time, execution condition, status and warnings, if any.
Show execution log
  1. Click in the base header, and then click Automation Rules.
  2. Move the mouse cursor over the automation rule whose log you want to view.
  3. Click on the three dots and then on Open log.
Structure of the execution log
You can view the following information in the execution log of an automation:
Execution time
Here SeaTable stores the exact time when the trigger initiated the automation.
Execution condition
If the automation is triggered by the change or addition of a record, the message per_update appears. On the other hand, if the automation is triggered periodically, the message per_day/week/month appears.
Status
The status indicates whether the automation was executed successfully. If this is the case, the message Success appears here.
Warnings
If there were problems during the execution of an automation, a corresponding warning message appears here.
