In the editing mode of SeaTable apps you can choose between different page types for the design of your app. Most of the page types you already know in a similar form from other places in SeaTable.
In this overview article, you will learn about the available page types and their different uses.
You can currently choose from a total of 10 page types in the app builder.
Page Types SeaTable App
Learn how to create new pages in SeaTable apps here.
To edit existing pages, click on the gearwheel icon of the corresponding page in the navigation.
Click on the edit icon
You can use this page type to add any table from your base as a page to your app. You can use the page permissions to control exactly who can see and edit the data on this page. You can also define preset filters, sorting, grouping and hidden and read-only columns to tailor, limit and organize the displayed data precisely to a user group.
Using the page type: Table added to your page
Learn more about table pages in SeaTable apps.
You can use this page type to build different forms that users can then submit. Web forms are not only available in the app, but also as a separate feature. Form pages in the app are ideal for collecting data from many different users. One possible use case is recording working hours .
Web form for recording the working time of your employees
Learn more about form pages in SeaTable apps.
Using this page type you can display images that you have saved in an image column of your table in the form of a gallery. Other data from your table can also be displayed in the gallery. For example, you could use a gallery page for clear profiles of your employees.
Representation of your employees in a gallery page
Learn more about gallery pages in SeaTable apps.
This page type allows you to display records with one or two date columns in a calendar. For example, a concrete use case could be the calendar display of upcoming meetings.
Upcoming meetings in a calendar view of the calendar page
Find out more about calendar pages in SeaTable apps.
With this page type, you can let your creativity run wild and build a custom page just the way you want it. Add text and images to your page or use statistics to create meaningful dashboards with the data from your base.
Management dashboard in the working time recording app
Find out more about custom pages in SeaTable apps.
This page type allows you to display records as cards on a Kanban board. To do this, specify the column by which the records should be grouped. A specific use case could be the visualization of workflows and project progress, for example.
Use case of the page type: Kanban
Learn more about Kanban pages in SeaTable Apps.
This page type allows you to display different time spans in the form of a timeline. For example, a concrete use case could be vacation planning in a company.
Use case Page type: Timeline
Learn more about timeline pages in SeaTable apps.
Using this page type, you can search your records across specific fields for specific values. The page type proves particularly useful for large datasets such as product catalogs or libraries. For example, a specific use case could be querying identification numbers.
Use case Page type: Query
Learn more about query pages in SeaTable apps.
This page type displays geolocation data or addresses on a world map to illustrate geographic distributions. For example, you can use it to display company locations on a map.
Use case Page type: Map
Learn more about map pages in SeaTable apps.
This page type allows you to design a page with static elements, dynamic table fields, colors, frames, etc. in order to visually prepare the data stored in a row. Users of the app can browse, search or edit the individual data records on this page. This type of page is therefore suitable for displaying the data in an employee database as personal profiles, for example.
Switch between records on single record pages
Learn more about single record pages in SeaTable apps.
