With this page type, you can give free rein to your creativity and build a customized page according to your wishes. Add text and images to your page or use statistics to create meaningful dashboards with the data from your base.
Management dashboard in the working time recording app
If you want to change the settings of a page, click on the corresponding cogwheel symbol in the navigation bar.
Change the settings of the custom page
You can use the page settings to add various elements to your page using drag-and-drop.
Drag and drop elements on custom pages
If you want to copy, move or delete an existing element on your custom page, simply use the three corresponding symbols in the top right-hand corner of the frame.
Copy, move and delete elements on custom pages
There are additional settings for each element of the custom page, which mainly affect the formatting and graphic configuration.
Text elements are particularly suitable for headings or short texts that you want to place on your custom page.
Add texts to custom pages
You can define numerous parameters in the element settings:
  • Font type, size, thickness and color
  • Line spacing and text alignment
  • Background and framework
Element settings for texts on custom pages
As the name suggests, you can use formatted text elements to format longer texts. This opens the text editor that you already know from the formatted text column type.
Formatted texts on custom pages
As you already have a wide range of formatting options in the text editor, you can only set the background color and the frame of the text box in the element settings.
Element settings for formatted texts on custom pages
To separate different areas on your custom page, you can draw a horizontal line. You can specify a color, a background and a frame.
Element settings for lines on custom pages
You can easily add pictures to make your custom page more attractive. To do this, click on the picture frame that you have previously embedded in the page using drag-and-drop and upload the desired picture from your device.
Add image to custom page
In the element settings, you can define the fill mode, the background and the frame of the image. You can also use hyperlinks to link other pages of the app or external resources on an image.
Element settings for images on custom pages
A container provides a grid with which you can arrange other elements (e.g. texts, images, statistics) more easily and group them together. First of all, you therefore define how many rows and columns this grid should have. This results in the individual boxes into which you can insert other elements using drag-and-drop.
Container element on custom page in SeaTable 4.3
In the element settings, you can add a title to the container, the font size, font weight and alignment of which you can adjust. You also have the option of setting the background color and the frame of the container.
Element settings for containers on custom pages
The card, which combines an image, a headline and a text into a design template, also ensures a beautiful page layout.
Card element on custom page in SeaTable 4.3
You can insert an image, a title and card content (text) into this template. You can also use a hyperlink to link to another page of the app or an external resource.
Element settings for cards on custom pages
As far as the design of the card is concerned, you first have the option of changing the fill mode of the image. Next, you can adjust the font size, weight and color of both the title and the card content. Finally, you can set the background color and the border of the card.
Style settings for cards on custom pages
On a custom page of your app, you can visualize the data from the underlying base using various graphics and diagrams.
Add statistics to custom pages
The configuration of statistics is very similar to the statistics module in the base. First select the table from which the statistics should display data. You can change the chart type by clicking on the opposite arrows.
You can filter the entries to narrow down the data displayed in the statistics. To do this, click on Add filter, select the desired column and condition and confirm with Submit.
Filter displayed data from statistics
You can also activate the drill-down function and specify exactly for which columns the data should be displayed when you click on the statistics. If the function is deactivated, the chart does not allow any deeper insights into the underlying data. The user only sees the chart itself.
Drill-down function for statistics
For a bar chart, you must specify the column that is to provide the values for the x-axis. Click on the corresponding drop-down field and select the column. You can use a slider to set whether you want to include empty rows in the chart.
Data settings of statistics on custom pages
Then decide how the values should be displayed on the Y-axis. You can choose between the number of entries that have a specific value in the selected column and the Summarize field option, where you can evaluate either the sum, the average, the number of unique values, the maximum or the minimum in numerical columns.
Data settings Y-axis of statistics on custom pages
For grouped charts, you can specify a column with options by which you want to group. For some chart types, you can also sort the data in ascending or descending order.
Depending on the chart type, you have different style settings to choose from.
For example, you can make the following settings for a bar chart:
  • Title, font size, font weight and alignment
  • Display the title of the X and Y axis
  • Automatic limits or minimum and maximum of the Y-axis
  • Color and data labeling of the columns
  • Frame (shade, color, thickness and radius)
Style settings for bar charts on custom pages
You can make the following settings for a pie chart:
  • Show legend and labeling
  • Position, format and font size of the labels
  • Minimum share of a sector
Style settings for pie charts on custom pages
All setting changes are carried out in real time, i.e. the diagram is updated immediately each time a setting is changed. This allows you to see immediately whether you have achieved the desired result or need to make adjustments.
There is a special type of statistics on custom pages: Similar to table pages , the simple table allows the tabular display of a data set that has been pre-filtered and pre-sorted by the app admin. Unlike on the table page, it is therefore possible to combine several tables on one dashboard.
New chart type “Basic table”
In addition to the colors of the custom page elements, you can also set the background color of an entire custom page.
Set the background color of the custom page
Choose between white, grey and your own color, which you can enter using a hexadecimal code or specify freely in the color selector.
If you want to hide the title bar on an custom page, you can do this by activating the corresponding slider.
Last but not least, you can limit who can see the page in the page settings.
Authorization for custom pages
This is the only page authorization you have to choose from for custom pages - because custom pages cannot be used to add, change or delete rows in the table.
