Congratulations! You started this course working alone on a base, and you are finishing it able to work on shared data as a team — confidently and safely. Let us briefly recap what you have achieved.
What you have learned
- You can share a base with a colleague and pick the right permission level — Read-Only, Read-Write, or, on a paid plan, a custom share that exposes only chosen tables and views.
- You can discuss records in context with comments, and you know that only an @mention actually notifies a colleague, while a plain comment quietly waits on the row.
- You can read the history in the activity log, the base log and the row log to see who changed what, and restore a single change without disturbing anything else.
- You can distribute a live dataset to another team with a common dataset, keeping your master private and authoritative while their copy stays in sync and they build their own work on top of it.
- You can collaborate visually in real time on the whiteboard.
Together, these are some everyday tools of teamwork in SeaTable, but you can probably find your own new ones! The thread running through all of them is the same: share deliberately, keep one authoritative source of truth, and let everyone see who did what.
A few habits worth keeping
- Share the minimum. Give colleagues the access they need and no more. When two teams need different slices of the same data, reach for a common dataset before you hand over the whole base.
- Keep the conversation on the data. A comment on the row outlives any email thread, and anyone who opens that record later will understand the history at a glance.
- Trust the log, not your memory. When a value looks wrong, check the history before you retype it — and restore rather than guess.
Where to go next
You can now set up a base that a whole team works on together. If you want to keep going, here are two good next steps:
- Course 4 – Automation & Integration: you have done a lot by hand in this course — making changes, sending notifications by @mention, synchronizing data. Next you will let SeaTable do this work for you automatically, and connect it to the other tools your team uses.
- Course 5 – Apps & Reporting: turn the data you collaborate on into polished apps and reports for the people who only need to read or submit, not edit.
Test your knowledge
You have reached the end of the course. Now you can take the quiz to test what you have learned.
- The quiz is in English and consists of multiple-choice questions about the collaboration features you have used.
- Don’t worry if you don’t pass straight away — you can repeat it as often as you like until you reach the required score.
- Upon successful completion, you receive a badge for your community forum profile, so your skills are visible to others.
Thank you for taking the course — now go and collaborate. Good luck on your journey with SeaTable!
