This script demonstrates how to run SQL queries in SeaTable using base.query(). Unlike base.list_rows(), SQL lets you filter, group, and aggregate data without loading all rows. The script is suitable for manual execution or as an automation.
base.list_rows() base.query()
Filtering Only via view filters WHERE clause
Grouping Not possible GROUP BY
Aggregation Not possible SUM, COUNT, AVG, MIN, MAX
Default limit 100 rows 100 rows
Maximum limit 1,000 rows 10,000 rows
The script runs various SQL queries against an orders table and prints the results. Adjust TABLE to match your table structure.
base.auth()
TABLE = "Orders"
# 1. Filter: unpaid orders
print("=== Unpaid orders ===")
rows = base.query(f"SELECT Product, Customer, Amount FROM `{TABLE}` WHERE `Paid` = false")
for row in rows:
    print(f"  {row['Product']} - {row['Customer']} - {row['Amount']}")
# 2. Aggregate: total revenue per category
print(".")
print("=== Revenue per category ===")
rows = base.query(f"SELECT Category, SUM(Amount) AS total FROM `{TABLE}` GROUP BY Category")
for row in rows:
    print(f"  {row['Category']}: {row['total']}")
# 3. Aggregate: orders per customer
print(".")
print("=== Orders per customer ===")
rows = base.query(f"SELECT Customer, COUNT(*) AS orders, SUM(Amount) AS total FROM `{TABLE}` GROUP BY Customer ORDER BY total DESC")
for row in rows:
    print(f"  {row['Customer']}: {row['orders']} orders, {row['total']} total")
# 4. Filter with date range
print(".")
print("=== Orders in March 2026 ===")
rows = base.query(f"SELECT Product, Customer, Date, Amount FROM `{TABLE}` WHERE `Date` BETWEEN '2026-03-01' AND '2026-03-31'")
for row in rows:
    print(f"  {row['Date']} - {row['Product']} ({row['Customer']}): {row['Amount']}")
# 5. Summary
print(".")
print("=== Summary ===")
rows = base.query(f"SELECT COUNT(*) AS count, SUM(Amount) AS revenue, AVG(Amount) AS avg_order FROM `{TABLE}`")
r = rows[0]
print(f"  {r['count']} orders, {r['revenue']} total revenue, {r['avg_order']:.2f} avg order value")
SeaTable supports the most important SQL operations:
  • WHERE — Filter with =, !=, LIKE, IN, BETWEEN, IS NULL
  • GROUP BY — Group with SUM, COUNT, AVG, MIN, MAX
  • ORDER BY — Sort (ASC/DESC)
  • LIMIT / OFFSET — Limit results (max 10,000)
  • DISTINCT — Unique values only
The full SQL reference can be found in the SeaTable Developer Manual .
