This script merges multiple PDF files stored in a file column into a single PDF document and saves the result back to the row. This is useful for combining invoices, reports, or other documents.
The complete script
import pdfmerge
from io import BytesIO
import os
base.auth()
TABLE_NAME = "Documents"
FILES_COLUMN = "PDF Files"
RESULT_COLUMN = "Merged PDF"
for row in rows:
files = row.get(FILES_COLUMN, [])
if not files or len(files) < 2:
continue
if row.get(RESULT_COLUMN):
continue
# Download all PDFs
tmp_files = []
for i, f in enumerate(files):
url = f if isinstance(f, str) else f.get('url', '')
content = base.download_file(url)
tmp_path = f"/tmp/pdf_{i}.pdf"
with open(tmp_path, 'wb') as fh:
fh.write(content)
tmp_files.append(tmp_path)
# Merge
output_path = "/tmp/merged.pdf"
pdfmerge.pdfmerge(tmp_files, output_path)
# Upload
with open(output_path, 'rb') as fh:
info = base.upload_bytes_file("merged.pdf", fh.read())
base.update_row(TABLE_NAME, row['_id'], {RESULT_COLUMN: [info.get('url')]})
# Cleanup
for f in tmp_files:
os.remove(f)
os.remove(output_path)
print("PDFs merged.")
The script skips rows that already have a merged PDF or have fewer than two files. Adjust the column names to match your table structure.
