This script converts text values (e.g., product IDs, serial numbers) into barcode images using the Code 128 format and saves them as images in SeaTable. Only rows without an existing barcode are processed.
import barcode
from barcode.writer import ImageWriter
from io import BytesIO
base.auth()
TABLE_NAME = "Table1"
TEXT_COLUMN = "Product ID"
IMAGE_COLUMN = "Barcode"
for row in rows:
    text = row.get(TEXT_COLUMN)
    existing = row.get(IMAGE_COLUMN)
    if not text or existing:
        continue
    code128 = barcode.get_barcode_class('code128')
    rv = code128(str(text), writer=ImageWriter())
    buf = BytesIO()
    rv.write(buf, options={"module_width": 0.4, "module_height": 10, "quiet_zone": 1, "font_size": 10, "text_distance": 2})
    buf.seek(0)
    info = base.upload_bytes_file(str(text) + '.png', buf.read(), file_type='image')
    base.update_row(TABLE_NAME, row['_id'], {IMAGE_COLUMN: [info.get('url')]})
print("Barcodes generated.")
Adjust TEXT_COLUMN and IMAGE_COLUMN to match your column names. You can customize the barcode appearance by modifying the options (module_width, module_height, font_size, etc.).
