The page design plugin offers you a variety of options for visualizing the information in a table in the form of personalized cover letters, business cards and newsletters, among other things. With the help of static elements you can create page layouts that are supplemented by dynamic elements and table fields.
Read the article Activating a plugin in a base to find out how to activate the page design plugin and add it to your toolbar.
  1. Open the page design plugin.
    Open the page design plugin in your base
  2. Click on the new page with the plus symbol.
    Click on the + symbol
  3. Select the option Create blank page.
  4. Here you can make the following settings:
    • Select the table from which you want to use data.
    • Decide on a paper size.
    • Specify portrait format or landscape format for the page layout.
      Settings of a page in the page design plugin
If you have created a new page design, you can save it via the  Done button. You can edit it again after clicking on the  Edit button in the same place.
Edit a page in the page design plugin and save the changes
Outside of edit mode, you can see the saved  Versions of the page design and restore them.
You can undo or redo individual editing steps by clicking on the arrow icons  and  .
Undo or redo individual editing steps
Via the button  Full screen button to display the page design across your entire screen. If you want to save a document as a PDF on your device, click  PDF, enter the name of the export file and confirm with Export.
Display page design in full-screen mode and save as PDF document
Click on  Print to print the current entry or all entries in the view. As soon as you confirm with Print, the usual window opens in which you can make the print settings on your device.
Print entries of a page design plugin
In the page design overview, which you can access via the back arrow  in the top left-hand corner, you can see all your saved designs. If you move the mouse pointer over a document there and click on the three dots that appear, a drop-down menu opens with the options Rename, Copy, Export and Delete.
Options in the page design overview
The page elements offer you the option of designing standardized layouts. You can choose between the following elements:
  • Static elements
  • Dynamic elements
  • Table fields
  • View elements
  • Header and footer
You activate an element by embedding the respective field by drag-and-drop in the page. You can then move the element on the page by clicking and dragging it with the mouse.
Activate static image
Select an element inserted on the page by clicking on it with the right mouse button. In the panel to the right of the page, you will see various setting options depending on the selected element. You can find out more about the respective options in the following chapters on the elements.
You can lock, duplicate or delete an element with one click by selecting the corresponding options.
Lock, duplicate, delete static image
The static text offers you the option of integrating text elements such as headings or body text into a page. This is very useful for creating templates for documents that you can later personalize with data from your table.
Unlike text that comes from text columns in your table, static text does not change and remains the same regardless of the entries in the table. However, you must manually insert and format the corresponding text.
You can determine the position of the text element on the page by entering the X- and Y-coordinates. Alternatively, you can also simply move the text element to the desired position by drag and drop.
Static text size and position
Move static text
The Width and Height fields change the size of the text frame. Alternatively, you can also change the size directly on the page by clicking on the text field with the right mouse button and dragging the small square at the bottom right-hand corner of the frame.
Enlarge static text field
With Rotation, you set the angle at which you can rotate the text box around its top left-hand corner. This function allows you to create vertical lettering (at 90 or 270 degrees).
As soon as you use several text elements, these are superimposed in layers. If you want to change the order of the layers, you can do this via the settings. Click on the various buttons to move the text either one layer to the front/back or completely to the foreground/background.
Change static text order
Enter the text either in the text field in the settings or in the text frame directly on the page. You can select a text frame on the page at any time by clicking on it with the right mouse button.
Static text input
Set the font, the font size and the font weight.
Static text font settings
You can adjust the line height as well as the horizontal and vertical alignment of the text in the corresponding fields.
Change static text spacing and position
Change the text color by entering the hexadecimal color code or clicking on the color field. You can adjust the Background color in the same way if you select the Filled option.
Static text font color and background color
Increase the Internal spacing of the text to reduce the area filled with text within the frame.
Static Text Inner Spacing Vertical Text
Add a complete frame to the text by activating the controllers for all sides of the rectangle. You can give the text individual outlines if you only activate the sliders for certain sides. Specify the frame color by entering the hexadecimal color code or clicking on the color field. To adjust the frame thickness, simply set the numerical value.
Static text frame
You can use the frame radius to round off the corners of the frame until a circular arc is created.
Static text frame radius
A static image offers you the option of integrating image files such as logos, graphics or background images into a page to create a basic page layout. In contrast to images that originate from image columns of your table, a static image does not change and remains the same regardless of the entries in the table. However, you must upload the corresponding image file manually.
You can determine the position of the image on the page by entering the X- and Y-coordinates. Alternatively, you can simply drag and drop the image to the desired position.
Static image size and position
Moving a static element
Use the Width and Height fields to change the size of the image. For Rotation, set the angle at which the image is rotated around its top left corner point. Alternatively, you can also change the size of the image directly on the page by clicking on the image with the right mouse button and dragging the small square at the bottom right-hand corner of the frame.
Enlarge static elements
As soon as you use several images, these are superimposed in layers. If you want to change the order of the layers, you can do this via the settings. Click on the various buttons to move the image either one layer to the front/back or completely to the foreground/background.
Change static image order
To insert a file into the image frame, click on the field with the document symbol under image or double-click directly in the image frame on the page. In the window that opens, select an image file from your device and upload it.
Use the Customize, Fill and Stretch fill modes to select how the image should be fitted into the frame.
Static elements fill modes
Especially when using PNG files with a transparent background, it can be useful if you fill the background with a color in the settings. However, this also works for other file formats. Click on Filled and select a background color by entering the hexadecimal color code or clicking on the color field.
Color static image background
Increase the internal spacing of the image to reduce the size of the image within the frame.
Static image inner spacing
Add a full frame to the image by activating the controllers for all sides of the rectangle. You can give the image individual contours if you only activate the sliders for certain sides. Specify the frame color by entering the hexadecimal color code or clicking on the color field. To adjust the frame thickness, simply set the numerical value.
Create static image frame
You can use the frame radius to round off the corners of the image frame until a circular arc is created.
Static image frame radius
Dynamic elements change based on certain criteria, but independently of entries in the table. These fields are pre-filled and adjust their contents automatically. There are three dynamic elements:
  • Current date
  • Template name
  • Current user
The settings that you can make for dynamic elements are the same as for static text elements.
The current date automatically adjusts to the current date without you having to set it manually. This allows you to create personalized cover letters, for example, without an outdated date creeping in.
The only additional setting compared to static text elements is the Format setting. Here you can choose from the different regional spellings for dates.
dynamic element date format
You can embed the name of the page design you are currently editing in the page. If you change the template name, the text in this field will automatically adapt.
Dynamic element template name
Your own name appears in the Current user field if you are currently making changes to the template via your account. As soon as another team member calls up the template in the page design plugin, their name is displayed.
Dynamic element current user
As table fields, the page design plugin lists all columns of the table from which you can insert data into the page. As it depends on the number and type of columns which table fields you have to choose from, you have different options depending on the table. The content of the fields depends on the data in the table and changes depending on the entry (data record in a row).
If you switch between the entries using the Previous entry and Next entry navigation options, data from other rows is automatically displayed in the table fields.
Second entry of the table used for the page plugin
Entry two when using the page plugin
This makes it clear: with the help of table fields, you can quickly display information from the respective data records in your template and create different versions of a document. You can also use the Expand record button to open the Row details to edit the respective entry in the table.
The columns of the “Budget Book” table are to be displayed as table fields in the page design plugin.
Budget Book table example
Create a new page in the plugin or open a saved page design. The columns of the table are now available as table fields in the page elements.
Table fields of the Budget Book table
Drag and drop the table fields to the desired positions on the page. The table fields are automatically filled with the column information of an entry.
Page Design Plugin Example Budget Book
It is important to understand the difference between entries and pages. Pages always refer to the same row in a table, while entries represent the data records from different rows.
You can add pages to expand the document and create a multi-page template. To do this, click on the Add page button.
Inserting a page in the page plugin
By right-clicking you can call up a drop-down menu which offers you additional options for a page.
The drop-down menu of the pages in the page plugin
To switch between the pages, simply click on the corresponding page thumbnail in the page bar. You can change the order of the pages by holding down the mouse button on the six dots  and moving the page thumbnail.
You also have two view elements to choose from. The All view items element allows you to embed the entire table section defined in a view into the page. The View name only contains the name of the selected view.
View elements
You can insert headers and footers as special areas on a page and fill them with several elements, whereby you decide on the content and arrangement of the elements yourself. With headers and footers, you have the option of inserting page numbers and blocking several elements at the same time.
You can only vary the height of headers and footers, as these always extend over the total page width. In the Height field, enter the desired numerical value or change it using the arrow keys or scroll with the mouse wheel.
Setting the height of the header and footer
Alternatively, you can also change the height directly on the page by clicking on the header or footer with the right mouse button and dragging the small square at the bottom right-hand corner of the frame.
You can insert six different elements in headers and footers.
Static elements:
  • Static text
  • Static image
Dynamic elements:
  • Current date
  • Page number
  • Template name
  • Current user
You can lock or delete headers and footers by selecting the respective option. If you lock a header or footer, all elements that you have previously inserted in this area are also locked. The same applies to deleting, whereby you also delete all elements in a header or footer.
Locking and deleting with the page plugin
