Here you are at the end of the journey. Look back for a moment: you took a warehouse that received its deliveries by hand, and turned it into a process that triggers itself, checks itself, updates the stock, and carries word to whoever is waiting on the dock. Let’s take the time to name what you have learned — because behind the warehouse scenario are skills that hold true for any project.
Three directions
Everything you have built falls into three directions, depending on where the information comes from and where it goes.
Inside SeaTable. The no-code automations — linking by comparison the instant a line appears, then sweeping your deliveries on a schedule to assign whoever must settle a dispute — and the Python scripts — updating a stock, creating rows — act on your data without ever leaving the base. This is the backbone: the most accessible one, and the one everything else leans on.
To the outside. Webhooks and n8n send information out: a notification on your phone, a file archived in another service. SeaTable tells the world, or hands it a task.
From the outside. The API lets other systems write into your base: a supplier whose delivery note is generated the moment the truck is loaded drops its lines there directly, with no paper in between. SeaTable doesn’t live in a bubble, it hooks into what already exists.
And, cutting across all of this, artificial intelligence: it read a delivery note for you. A powerful accelerator — provided, as you saw, that you always keep the human in the loop.
The quiz
All that’s left is to put your knowledge to the test. The quiz actually takes the shape of a SeaTable form — one last nod to what you have just learned. It mixes questions about the features you came across and questions about the base you have equipped throughout the course.
When you’re ready, open the Course 4 quiz. If you pass, you receive a badge for your profile on the forum, which makes your skills visible.
What’s next?
The process you have built was deliberately kept simple to get to the point, but it already opens up a thousand next steps: plugging a third service into your workflow, having a document signed before it is filed, refining each automation as your needs grow… You now have the building blocks; it’s up to you to assemble them for your own needs.
And here is one challenge to stand on your own feet. All along you worked in a single direction — deliveries arriving from your suppliers, adding to the stock. But your base carries a second Movement type for the opposite direction: the Customer order, where goods leave your shelves. Point the same building blocks the other way — when a customer order comes in, check the stock is there, record what goes out, subtract it from Stock, and alert whoever needs to know. It is the patterns you already know, running in reverse — and this time, no one walks you through it.
Thank you for taking this course, and well done for the road you have traveled.
