A Kanban board can be useful to represent dynamic processes with different phases. In this respect, it allows you to visualize workflows and project progress, for example. This is particularly helpful for project planning, product development or task distribution in the team.
Good that SeaTable offers you all these possibilities with the Kanban plugin. You can learn how to activate the plugin in a base here .
The Kanban board consists of columns that stand for different steps or phases in a process. In a workflow, for example, these can be “idea”, “in progress”, “done” and “planned”.
Kanban plugin
You provide the columns with movable cards that you can move both within a column and from one column to the next. For example, a card can stand for a work package or a task.
Kanban shifts
Via the settings, which you can reach by clicking on the gear icon , you can define the following for the Kanban board:
  • Table
  • View
  • Grouping
  • Title
  • More columns
  • Controller options
If you have several Tables and Views created in your base, you can choose from them.
The grouping determines which column defines the columns. Selection are particularly suitable for this.
Kanban plugin columns
In this example the column Status chosen. As pillars were thereby the Options “idea”, “in progress”, “done” and “planned” defined.
The entries in the column you specify under Title determine the heading of the cards of a Kanban board.
Kanban plugin title
Kanban plugin more settingne
Here all Columns that you have created in your table. By activating the individual Controller the entries in the respective columns become visible as informative notes on the cards.
Via the slider options you have the possibility to change the visual representation of the Kanban board.
  • The Do not show empty values slider allows you to remove grayed placeholders on the cards.
  • The Show column names slider shows the column names above all activated information.
  • The Wrap Text slider formats texts so that they are fully readable on the cards of the Kanban board.
Kanban Plugin Rule Options
