To store information, instructions or explanations about a column, you can add a description to your table columns in SeaTable. Here you will learn how to do that:
Adding a column description
  1. Click on the triangular drop-down icon to the right of the name of a column  .
  2. Select the Edit column description option.
  3. Enter a description of the column in the text box that opens.
  4. Save your input with Submit.
The column description is displayed when you move the mouse cursor over the info icon  .
