You can hide the column arrows with which you open the drop-down menu of the column options. This makes sense, for example, if you no longer want to change the finished configuration of the columns and want to have a clearer view.
Hide column arrows
  1. Click the gear icon  on the far right of the table header.
  2. Select the Hide drop-down arrow option.
