Whether it is adding new users, assigning roles or creating invitation links - you can perform various administrative activities in the user and role administration of an app. You can access the user and role administration via the edit mode of your app.
  1. Open a base to which you have already added an app.
  2. Click Apps in the base header.
  1. Hover your mouse over the app and click the pencil icon  .
Click on the edit icon
  1. Open the user and role administration at the top left of the page.
Icon for user and role administration
  1. Make the desired settings.
In the first section you will find an overview of all users who have access to your app. In addition, you will also find the role and status of the respective user.
Overview of the Users tab of the User and Role Management of an app
This section also provides you with various options for managing the current users of your app.
Use the search function to find a specific user. This feature can be especially helpful if you have a large number of app users.
Search function for app users
To add a user to the app, click Import User, search for the user using the input field, and then assign a role to the user.
Click Import User
Import a user to your app
Click Synchronize users with base to automatically collect the app users in a table of your base.
Click Synchronize user with base
Table in which app users are automatically collected
If you add more users this way in the future, you can always click Synchronize users with base again to add the new users to the table.
If you add more users to your app in the future, …
… you can always click Synchronize users with base again to add the new users to the table automatically.
To delete a user from the app, simply click on the X icon, which you can find to the right of the status of the respective user.
Delete user
By clicking on the pen icons  , which you can find for each user, you can edit their role and status.
Editing icons for each user
For the role of a user you can choose from all roles in the drop-down menu, which you can define in the next section of the user and role administration.
Selection of the role of a user
The status of a user can be set to Active or Inactive. While active users have access to the app and its content, inactive users lose this access.
Editing the status of an app user
Users who do not have access to your app will see this message:
Denied access to the app for inactive users
In this section you can define any number of roles, which you can assign to different app users in the section above.
Definition of different roles for the app users
Here you initially define only the names of the roles. You can define which permissions users with the different roles have individually for each page of the app.
Learn more about page permissions here.
In the third section of User and Role Management, you can generate an individual invitation link for the app.
First, define the role of the users who will access the app using the invitation link.
Selection of the role that will be given to the user who will use the app using the invitation link.
Afterwards, you have the option to set a password that must be entered after opening the invitation link in order to gain access to the app.
Adding a password to the invitation link
Optionally, you can also add an automatic expiration time to the invitation link, how long it is valid.
Add automatic expiration time to invitation link
With a click on Generate you can have the invitation link created. The link will be displayed below and you have the option to copy or delete it.
Generated invitation link along with available options to copy and delete the invitation link.
Alternatively, you have the option to generate a QR code to open and share the app.
Display the QR code to open and share the app.
Scan the displayed QR code to open your app or share it with other users to give them access to your app.
