Are you an Excel user who is familiar with writing formulas and just getting started with SeaTable?
If so, this article is for you! Although the principles of the formula functions in SeaTable are similar, there are some important differences that you need to learn at the beginning that will pay off if you want to become an expert in SeaTable formulas.
The most central and important difference in the formula function of SeaTable and Excel is the scope of the formulas.
While in Excel you can enter a formula in any cell and it will subsequently refer to any other cell in the spreadsheet, formulas in SeaTable refer to entire columns and not to specific cells.
Since SeaTable acts as a relational database in this context, formulas are applied to the entire column of a table so that the same formula applies to each entry in that column.
Any particular cell can be referenced in another cell. For example, to determine the source of each purchase in a table, you would write a formula that references each
cell - like A3 - to check the type of source.
The formula used below is:
= IF(A3 = “Online”, “Web”, “Store”)
Cell referencing in Excel
The formula refers to specific cells, such as A3.
A formula is always applied to an entire column and not to specific cells. For example, to identify the source of each purchase, you would write a formula that references the {Purchase Type} column, and the formula will check that column for each entry in the table.
The formula used for this below is:
IF({Purchase Type}= “Online”, “Web”, “Store”)
Column referencing in SeaTable
The formula refers to whole columns, such as {Purchase Type}.
SeaTable formulas work within tables, not across bases.
Similar to above, by default SeaTable formulas only refer to columns within the same table. However, there are also ways to take a value from another table to reference it in a formula field (This approach uses linked records, which are discussed in more detail here ).
To refer to a record in another table, you must write specific references to the other table in a format such as the following:
=IF(Tasks!B1=‘Home improvements’,Tasks!A1,0).
Then you need to apply this formula to each cell where you want to run the formula (changing the cell references for each cell where you want to run the formula).
Reference to other data set in Excel
To reference a record in another table, you can first link it using the “Link to other records” column type. Once a record in one table, such as Projects, is linked to a record in another table, such as Tasks, you can reference any row in both tables by using a lookup, rollup, or count column.
In the following example, a rollup column is used to easily reference the cost of each task associated with a project and sum the expenses to determine the total project cost.
Rollup column to reference the cost of each task associated with a project and total the expenses to determine the total project cost.
The function thereby creates a number of possibilities to write both simple and complex formulas to reference data between tables.
