This article introduces you to a Python script that outputs the complete metastructure of a base. This is useful, for example, if you have a question about a base in the community forum and want to describe the structure of your base easily and quickly without screenshots.
The metastructure of a base
The metastructure of a base describes the tables, columns and views of a base. The entries and records in the rows are not included in the metastructure. The following JSON structure describes a comparatively simple base with only one table, two columns and one view.
"metadata": {
"tables": [
"_id": "0000",
"name": "Table1",
"columns": [
"key": "0000",
"name": "Name",
"type": "text",
"width": 200,
"editable": true,
"resizable": true
"key": "BydO",
"type": "date",
"name": "Date",
"editable": true,
"width": 200,
"resizable": true,
"draggable": true,
"data": {
"format": "YYYY-MM-DD"
"permission_type": "",
"permitted_users": []
"views": [
"_id": "0000",
"name": "Default View",
"type": "table",
"is_locked": false,
"rows": [],
"formula_rows": {},
"summaries": [],
"filters": [],
"sorts": [],
"hidden_columns": [],
"groupbys": [],
"groups": []
"version": 482,
"format_version": 7,
"settings": {
"securities": {
"table_settings": {
"can_copy": false,
"can_export": false,
"can_print": false
"share_user_settings": {
"can_copy": false,
"can_print": false
This code is obviously impractical if you ask for help in the community forum, so the structure of this table should be reduced to the following rows .
--- COMPLETE BASE STRUCTURE WITH ALL BASES AND COLUMNS ---
Table: Table1 (ID: 0000)
--> Name (text)
You can find out exactly how this works in this article.
The Python code for reading the metastructure
In SeaTable, only a few rows of Python code are enough to get the metastructure of a base. Specifically, a few rows are enough for authentication and one row for the metastructure.
base.auth()
print(metadata)
However, the result or the output of the metastructure is anything but user-friendly.
{'tables': [{'_id': '0000', 'name': 'Table1', 'columns': [{'key': '0000', 'name': 'Name', 'type': 'text', 'width': 200, 'editable': True, 'resizable': True}], 'views': [{'_id': '0000', 'name': 'Default View', 'type': 'table', 'is_locked': False, 'rows': [], 'formula_rows': {}, 'summaries': [], 'filter_conjunction': 'And', 'filters': [], 'sorts': [], 'hidden_columns': [], 'groupbys': [], 'groups': []}]}], 'version': 13, 'format_version': 9, 'scripts': [{'name': 'Untitled', 'url': '/scripts/zkon.py', '_id': 'zkon', 'type': 'Python'}]}
Putting the metastructure into a different form
The variable metadata now stores the entire metastructure with all its elements in JSON format. SeaTable or Python, respectively, of course offer possibilities to traverse these structures and interact with them.
With the following rows the metastructure can be put into the desired form.
print("--- COMPLETE BASE STRUCTURE WITH ALL BASES AND COLUMNS ---")
for table in metadata['tables']:
print('.')
print("Table: "+table['name']+" (ID: "+table['_id']+")")
for column in table['columns']:
print(" --> "+column['name']+" ("+column['type']+")")
What exactly happens here? First, you instruct Python to create all tables with a for-loop. Next, you enter a value with print the name of the table and its ID. Here you can also see how to access the individual elements with the square brackets.
Repeat the same for the columns. Through the for-loop, all columns of the respective table are output.
Addition of links
Now you are almost there. You could already use the metastructure so well, but one weakness of the previous script is that when you have linking columns, it is not obvious where exactly they link to. Therefore replace the last two columns with the following code:
link_target = ""
if column['type'] == "link":
link_target = " --> "+column['data']['other_table_id']
if column['data']['other_table_id'] == table['_id']:
link_target = " --> "+column['data']['table_id']
The complete script
The complete script is immediately executable in any SeaTable base without any adjustments. It will serve you well if you want to describe the structure of your base in the community forum.
base.auth()
print('.')
link_target = ""
print(" --> "+column['name']+" ("+column['type']+link_target+")")
