Different views can facilitate working with tables that contain a lot of information. You can also print these views.
Print a view
  1. First things first: the view you want to print must be currently selected.
  2. In the view options, click the three dots on the far right.
  3. Select the Print view option.
  4. The Print Settings window opens. Make your desired print settings here and click Print.
  5. Now the standard print window of your device opens, where you can see a print preview and make further settings, such as the printer to be used, the color and the number of copies.
  6. Click Print again in the print window to start printing.
You have the possibility to set the following printing options:
  • Paper size
  • Alignment
  • Column scaling
  • Font size
  • Scale
  • Title
  • Print number of lines
  • Wrap long text to multiple rows
  • Show only result without result type
