This article highlights some of the ways you can capture data in SeaTable.
If you have just opened a table, you can simply click with the mouse in a cell and enter data using your keyboard. If necessary, add a new row to the table for this purpose.
For quick transfer of small amounts of data, you can also use your computer’s clipboard. To do this, copy the data in an existing table and paste it into SeaTable using copy-and-paste.
SeaTable has a powerful data import that allows you to capture data from Excel and CSV files in different ways. If you wonder which import formats SeaTable supports, read the corresponding help articles.
Web forms are the tool of choice when you want to have new records entered into a spreadsheet not by yourself, but by people inside and outside your team. Sounds too good to be true? Then try it out right away!
Using automations, you no longer have to add entries to your tables manually, but can create them automatically when a previously defined trigger event occurs. You can learn more about this in these articles:
