SeaTable has a powerful import function to make it as easy as possible for you to import data records from XLSX or CSV files. In most cases, importing works without any difficulties. If you try to import too many records at once, SeaTable will warn you of the limit. While you can freely choose the limits for file size and number of rows on self-hosted SeaTable servers, SeaTable Cloud imposes certain limits on you.
Maximum file size and number of lines for SeaTable Cloud
When importing Excel files, SeaTable supports this for files up to a maximum size of 100 MB and up to 50,000 rows. Due to these generous limits, you should never have problems with the file size. If you have a file that is larger or has more rows , you will need to split it into two Excel files and perform the import in two steps.
Embedded graphics and files
Importing graphics and files via XLSX file is not possible. For such import you need to use SeaTable API, which allows you to import images and files without difficulties.
Links to other records
There is no way to import data into the column type Link to other records. Since SeaTable is a relational database, links also work differently from cross-references in Excel.
Everything about handling the link column in SeaTable can be found here.
Different file formats
The import function of SeaTable has been tested with files from LibreOffice as well as current files from Microsoft Excel. Other office programs (such as from the company Softmaker) are not actively tested, which may lead to different import results. If in doubt, use Microsoft Excel or the free LibreOffice to get the best results.
