In the following article you will find instructions on how to import data from Google Sheets into SeaTable.
  1. To be able to import files from Google Sheets into SeaTable, first save them as CSV- or Excel file.
    Save Google Sheet as CSV or Excel
  2. Afterwards you can import the files into SeaTable as usual.
  3. Detailed instructions for importing the files can be found in the respective overview article on Excel import or CSV import.
