Available with Enterprise
If you have an Enterprise subscription, you can also send notifications to selected users via automation. To do this, simply define an appropriate automation rule for any table view.
Send emails via automation
  1. In the base header, click and then click Automation Rules.
  2. Click Add Rule.
  3. Give the automation a name and specify the table and the view in which it should act.
  4. Define a trigger event that triggers the automation.
  5. Click Add Action and select Send Notification as the automated action.
  6. Confirm with Submit.
First define a trigger event for the automation.
Trigger events basically available for selection
The four options are:
  • Entries meet certain conditions after editing
  • A new entry is added
  • Periodic trigger
  • Periodic trigger for entries that meet a certain condition
Then select Send notification as the automated action. This is available as an action for all four trigger options.
Adding the automated action
In the next step, you select the users to be notified when the trigger event occurs. Note that you can only select users who have at least read access to the table or view.
Selection of users to be notified
In the last step, paste the content of the notification into the text field provided. To refer to entries in the table, simply write the name of the columns in curly brackets in the text.
Adding the content of the notifications to be sent out
Save the automation by clicking Submit.
A concrete use case for this type of automation could occur, for example, if you work as a manager in a company and want to order the booking of various training courses for your employees. In doing so, you would like to automatically inform the HR department, which ultimately books the trainings, about which training your employees would like to attend.
In concrete terms, this can be implemented with the help of a table in which various data on your company’s employees is maintained. In this context, you could collect, among other things, the names of the employees, the department and the last training booked by them.
Example table of the concrete use case of automation
With the help of an automation, a notification should now be sent automatically to selected employees in the HR department whenever a new booking is requested in the table, so that they can initiate the booking of the requested training for the corresponding employee.
First, give the automation a name (e.g. notification if training is booked) and select both the table (here: employees & trainings) and the view in which the automation should work.
Naming the automation and defining the table and view in which it should act
As a trigger event of the automation, select the option “Entries meet certain conditions after processing”.
Selection of the trigger event
In order to send the notifications only in case of requesting a new training, add as a filter condition that the entry in the column “last training booked” must be changed to one of the possible selection options in this column.
Adding a filter condition
You then define the action “Send notification” as the automated action.
In the next step, in the drop-down field, select the employees of the HR department to whom the notification should be sent when the trigger is triggered.
In the last step you can write the content of the notification to be sent in the provided text field.
If you subsequently request a new training for an employee in the selected table, i.e. change the entry in the “last training booked” column to the last training requested, the prefabricated notification is automatically sent to the selected users of the HR department.
The employees in the HR department receive the information that a training has been requested in the notification, which they reach via the bell icon , and can initiate the selected training for the corresponding employee.
Notification sent to the selected users after the trigger event has been triggered.
