Available with Enterprise
If you do not want to run automations for a certain period of time, you can pause them instead of deleting them. This has the advantage that you can simply reactivate paused automations, while you have to create deleted automations from scratch again.
Temporarily stop automations
- Open a table where you want to pause an active automation.
- Click in the base header and then click Automation Rules.
- Hover the mouse cursor over the corresponding automation rule and click the pause icon on the far right .
The selected automation rule is then paused. You can recognize this by the note (paused) added in red to the name of the automation and by the fact that the pause icon changes to a play icon .
Re-enable automations
To reactivate paused automations, simply follow the steps already described above and click on the Play icon .
The note (paused) to the right of the automation name then disappears again and the pause icon returns.
