The more columns you create to enter data, the more confusing your table becomes. To ensure that you always have an overview of your data, you can hide individual table columns that are not currently needed or are irrelevant. In addition, you can adjust the order of the columns as you wish using drag-and-drop.
Hide columns
- Click Hide in the view options of any table.
- Hide any number of columns by clicking on them. Using the search field, you can narrow the selection of columns or search for a specific column you want to hide.
Move columns
Hold the mouse button on the Six dots symbols
In addition, you can also move the columns directly in the table view using drag-and-drop. To do this, hold down the mouse button on the name of a column and move the column to the right or left.
