Ce script envoie des e-mails par SMTP directement depuis un script Python SeaTable. Vous pouvez l’utiliser pour des notifications, des rapports ou tout e-mail automatisé basé sur vos données SeaTable. Le script supporte le texte brut, le contenu HTML et les pièces jointes.
You need the SMTP credentials of your email provider. Common settings:
Provider Server Port
Gmail smtp.gmail.com 587
Outlook smtp-mail.outlook.com 587
Custom your SMTP server 587 or 465
import smtplib
from email.mime.text import MIMEText
from email.mime.multipart import MIMEMultipart
base.auth()
# SMTP configuration
SMTP_SERVER = "smtp.example.com"
SMTP_PORT = 587
SMTP_USER = "your-email@example.com"
SMTP_PASSWORD = "your-password"
# Email settings
RECIPIENT = "recipient@example.com"
SUBJECT = "Automated email from SeaTable"
BODY = "This is an automated email sent from a SeaTable Python script."
msg = MIMEMultipart()
msg['From'] = SMTP_USER
msg['To'] = RECIPIENT
msg['Subject'] = SUBJECT
msg.attach(MIMEText(BODY, 'plain'))
with smtplib.SMTP(SMTP_SERVER, SMTP_PORT) as server:
    server.starttls()
    server.login(SMTP_USER, SMTP_PASSWORD)
    server.send_message(msg)
print(f"Email sent to {RECIPIENT}")
You can extend this script to read recipients, subjects, or email content from your SeaTable tables using base.list_rows(). For HTML emails, replace 'plain' with 'html' in the MIMEText call.
