Only a successful cover letter will open the door to a personal interview and bring you one step closer to your dream job. That is why the cover letter is an integral part of every application. While you include your hard skills in your CV, you dedicate your cover letter to your soft skills. These have become increasingly important in recent years, which is why the personal cover letter has become more of a focus in the selection process.
With a cover letter, you have the opportunity to present yourself confidently and emphasize your positive qualities. On the one hand, it is about self-presentation by listing relevant qualifications, and on the other hand, it is about standing out from the crowd of applicants in terms of language.
Before you start writing, you should create an information sheet. After all, you need information about the company, the requirements and of course an overview of your own qualifications so that you can tailor your cover letter to the job advertisement.
Use your computer to research the Internet to gather information about the company.
A structured approach will help you to work out relevant information and not write too much later on. The cover letter is based on your application documents. You should compile these beforehand and adapt them to the job advertisement if necessary.
  1. Read the job advertisement carefully and write down what requirements you are expected to meet.
  2. Compare the requirements profile with your certificates, knowledge and experience. Look for matches that qualify you for the position and add important qualifications to your CV if you have not already mentioned them.
  3. Based on your hard skills and the requirements profile, ask yourself the following questions about your personal skills and answer them honestly:
    • What are my strengths and what can I improve?
    • Which tasks do I do with enthusiasm?
    • What do I want from the new job? In which area would I like to learn something?
These questions should reveal what makes up your personality and what sets you apart from others. To check the relevance of the insights gained above, it helps to present them in a table.
Various hard and soft skills are relevant for a cover letter.
  1. Write all your hard skills in the left-hand column of the table. In addition to professional experience, these include degrees, internships, foreign language and computer skills, as well as voluntary work.
  2. The right-hand column contains soft skills that you have acquired or developed during your work. These include, for example, team spirit, enthusiasm or assertiveness.
  3. Now mark which skills were mentioned in the job advertisement and should therefore be included in your cover letter.
You can put aside any qualifications that you have not marked as relevant to your application. Be consistent and also delete information that says something positive about you but does not fit the position.
You should create a table so that you don’t lose track of where you have applied, when and with which documents during your job search. SeaTable offers you a structured application overview so that you always have the information and documents you have prepared to hand. See all your applications and the associated documents at a glance and make it easier for you to create cover letters with the page design.
If you would like to use SeaTable for your application planner, simply register free of charge. You can find the template here.
Before you start formulating your application, it is important to define a uniform design for all your application documents. This will not only make your application look more coherent at first glance, but you will also convey that you work neatly and cleanly.
Choose a suitable font, line spacing and font size.
How you design your documents is entirely up to you, as there is no prescribed format. However, make sure that your writing is legible and that you structure your cover letter clearly. Below you will find some recommendations:
  • Font: easy to read, not too fancy, e.g. Times New Roman or Arial, ideally in 10-12 point size
  • Line spacing: minimum single line and maximum 1.5 lines
  • Length: maximum one DIN A4 page
  • Margins: top and bottom 2cm each, left and right 2.5cm
  • Alignment: left-aligned, exception: date
Of course, you can also apply these formalities to other application documents in order to create a uniform and coherent image.
The structure of a cover letter always looks the same and can be divided into six sections.
The perfect structure for your cover letter consists of six steps.
The letterhead is traditionally used when you send your cover letter by post. However, you should also add a letterhead to your cover letter when submitting it online. This contains your contact details as well as the address of the company and the recipient to whom you are sending your application. Make sure that you enter the address details in the correct order, as shown in the illustration.
The address should always be free of errors and without gaps. Check that the company name is complete. To avoid unnecessary errors, copy the spelling of the company from the website. The name of your contact person should be correct and, if given, with an academic title.
The date then follows, some distance away and right-aligned. In Germany, this is structured as follows:
Place, day.month.year.
You can write the month either as a number or as a word.
This is followed by the subject line with two to three blank lines. You can emphasize this with bold letters or a larger font, for example. This allows the company to identify your request immediately, which enables quick processing. Indicate here which position you are applying for and add the reference number if applicable.
Before you have the opportunity to shine with your qualifications, you need to attract the attention of your contact person. Address them personally by name and only use the impersonal term ladies and gentlemen as a last resort if you don’t know anyone by name. For more conservative companies, choose a classic form of address such as Dear Ms. XY to introduce your request politely. For start-ups, you can also try an informal form of address such as Hello dear marketing team, dear Ms. XY.
Write politely, because you want to sell yourself and your skills well in your cover letter.
The first impression counts. You should therefore pay particular attention to the first sentence in your cover letter. This is because it should arouse interest and decides whether the recruiter reads your application further. You should definitely avoid sentences such as I hereby apply for position XY, as these do not provide the recruiter with any relevant information about you as a person.
It is important that the first sentence does not get lost in the crowd with a boring phrase. Make it clear what sets you apart from the other applicants. Use concise keywords that describe your personality and skills and that you can pick up on in the main body. For example, start with a personal connection to the company, your uniquely high motivation or an exciting unique selling point.
The main section is the core of your cover letter. Here you should include all relevant information in five to seven lines. The aim is to present your skills and motives briefly and concisely and at the same time give the recruiter a comprehensive impression of your personality.
What makes you special? Address this question in detail here. Make it clear that you are qualified for all the tasks in the job advertisement and that you are also able to take on new challenges with your skills. To do this, combine the skills already listed in your CV with your soft skills. Give specific examples of situations in which you have acquired or applied skills in a professional or private context.
It is also important whether you fit in with the company on a personal level in addition to your professional qualifications. Show that you identify with the company’s values and want to integrate yourself into the corporate culture. You can achieve this by explaining how you will enrich the company and what motivates you to work there.
We’ve saved the best for last. Here you can enter your salary expectations or earliest starting date.
The final sentence is particularly important, as this is what the recruiter will remember the longest. It is therefore important that you radiate self-confidence and make it clear once again that you expect positive feedback. To achieve this, you should avoid the subjunctive mood. A conclusion such as I would be delighted to be invited to an interview comes across as reserved, as if you are unsure of your own qualifications for the position.
The aim of the cover letter is to be invited to an interview.
Keep your goal in mind: Go to the interview with self-confidence.
Find a good middle ground to sound friendly, polite and confident at the same time. A clear statement such as I look forward to meeting you in person at an interview is a good way to do this.
As with the salutation, the greeting should be appropriate to the company. “Yours sincerely” is always the safest choice for you.
Now all that is missing is your handwritten signature. You can either place this on the printed cover letter or, in the case of an online application, sign digitally via touchpad or scan your signature and insert it into your document.
List the required attachments at the end of your cover letter under the heading Attachments or Enclosures. These usually include your CV, work and internship references and certificates. Attach these to your application in a separate PDF file.
The classic cover letter, as explained above, can vary in certain cases. Depending on which case applies to you, you should adapt your application documents accordingly.
If you would like to apply as part of a school or university internship, recruiters require no or few professional qualifications. Instead, you will score points with suitable soft skills and interests that you pursue in certain subjects, vacation jobs, your free time or as part of your own projects and voluntary work.
Soft skills can be demonstrated through voluntary work.
Your contact person is also interested in your motivation. Why exactly do you want to work for this company? What do you hope to gain from the practical experience? Show what inspires you.
You may not always find a suitable position among the vacancies advertised by your dream employer. But that’s no reason to give up, because most companies offer the opportunity to send unsolicited applications. Your focus here is on extended research, as you have to gather all the information for your documents yourself. Be careful not to overload your application and reduce your cover letter to the aspects that seem most important to you.
Most applications are sent online these days. If you send your documents by e-mail, the cover letter should be attached as a PDF document. The subject, i.e. the position you are applying for, should be placed in the subject line provided. Write a short two-liner in the text field in which you name your contact person and refer to the documents in the attachment. End the text with a greeting and your name.
Is the content of your application ready and you want to put the finishing touches to it? Then you will find some helpful tips and examples here to perfect your application.
Pay attention to your writing style and the wording you use.
You can enhance your cover letter by paying attention to the dos and don’ts.
To express self-confidence, use active sentences and address people directly. Make sure you personalize your cover letter and stay true to yourself.
Here you will find formulation aids for various situations in the cover letter:
Establish company and topic reference
“I have already gained insights into journalistic work during several internships in the media industry. Now I would like to apply the skills I acquired there to the PR of your international company and develop them further.”
Packaging professional experience profitably
“Thanks to my 10 years in sales, I know how to inspire customers in direct contact, which is why I can successfully increase revenue in your sales team.”
Developing professional qualifications
“Thanks to my Romance studies, I have a B2-level command of Spanish and French and have applied and deepened this knowledge during internships abroad in Madrid and Paris.”
Establish soft skills
“In my position as deputy team leader, I have developed a collegial management style in which I treat my employees as equals and assign them tasks based on their individual skills. Together, we completed the project in half the allotted time.”
Before you send off your application, you should proofread it. In addition to a spell check, the following checklist will help you to ensure that your cover letter is complete:
  • Are all the names correct and are they spelled correctly?
  • Have you formulated your cover letter clearly and not too clichéd?
  • Does the recruiter get a comprehensive picture of your qualifications?
  • Have you worked out your unique personality sufficiently?
  • Can the recruiter assess what added value you bring to the company and whether you identify with the culture?
Now nothing stands in the way of writing your next successful application. SeaTable has created an online application planner for you so that you don’t lose track of your documents even if you have several applications. This will help you to plan your next steps, organize your documents and always stay up to date with the application process.
If you would like to use SeaTable for your application overview, simply register free of charge.
TAGS: Everyday Life & Leisure
