Этот скрипт преобразует текстовые значения в изображения штрих-кодов формата Code 128 и сохраняет их как изображения в SeaTable.
The complete script
import barcode
from barcode.writer import ImageWriter
from io import BytesIO
base.auth()
TABLE_NAME = "Table1"
TEXT_COLUMN = "Product ID"
IMAGE_COLUMN = "Barcode"
for row in rows:
text = row.get(TEXT_COLUMN)
existing = row.get(IMAGE_COLUMN)
if not text or existing:
continue
code128 = barcode.get_barcode_class('code128')
rv = code128(str(text), writer=ImageWriter())
buf = BytesIO()
rv.write(buf, options={"module_width": 0.4, "module_height": 10, "quiet_zone": 1, "font_size": 10, "text_distance": 2})
buf.seek(0)
info = base.upload_bytes_file(str(text) + '.png', buf.read(), file_type='image')
base.update_row(TABLE_NAME, row['_id'], {IMAGE_COLUMN: [info.get('url')]})
print("Barcodes generated.")
Adjust TEXT_COLUMN and IMAGE_COLUMN to match your column names. You can customize the barcode appearance by modifying the options (module_width, module_height, font_size, etc.).
