How can I run a script both locally and in SeaTable?
You can write your script so it works in both environments without changes. The trick is to check whether the context object is available:
from seatable_api import Base
try:
from seatable_api import context
except:
base = Base('your-api-token', 'https://cloud.seatable.io')
base.auth()
Which libraries are available in the cloud environment?
SeaTable Cloud runs Python 3.12 with the following third-party libraries pre-installed:
- seatable-api – SeaTable API client
- requests – HTTP requests
- Pillow – Image processing
- pandas – Data analysis
- numpy – Numerical computing
- scipy – Scientific computing
- openai – OpenAI API
- beautifulsoup4 – HTML/XML parsing
- python-dateutil – Date utilities
- PyPDF – PDF processing
- pdfmerge – PDF merging
- qrcode – QR code generation
- python-barcode – Barcode generation
- pillow-heif – HEIC image support
- ldap3 – LDAP operations
- markdown – Markdown conversion
Can I install custom libraries?
On SeaTable Cloud, you are limited to the pre-installed libraries listed above.
On a self-hosted SeaTable Server, you can install additional libraries in your Python Runner. See the Admin Manual for details.
How do I handle more than 1,000 rows?
The base.list_rows() method returns a maximum of 1,000 rows by default. To process more rows, use one of these approaches:
Option 1: Loop with offset
all_rows = []
offset = 0
while True:
rows = base.list_rows(TABLE_NAME, start=offset, limit=1000)
if not rows:
break
all_rows.extend(rows)
offset += 1000
Option 2: Use SQL query
rows = base.query("SELECT * FROM `Table1` LIMIT 10000")
SQL queries support up to 10,000 rows per request.
How do I debug complex data structures?
Use json.dumps() with indentation to pretty-print dictionaries and lists:
import json
print(json.dumps(metadata, indent=2))
