A care journal is a structured, voluntary record that is typically kept over several weeks. In it, family caregivers document exactly when and to what extent a person in need of care requires assistance with daily activities. Essentially, the focus is less on which specific tasks were performed—such as help with dressing, eating and drinking, or walking—and more on how independently the person can still perform these activities and how much time the assistance takes.
With the help of a care diary, you essentially translate the day-to-day reality of caregiving into a transparent, reliable database. This allows you to document the actual care needs to the relevant authorities. Ideally, the care diary should follow the same structure that forms the basis for assessments by medical services or long-term care insurance providers.
  • Family caregivers are not required to keep a care diary.
  • A care diary documents the actual care needs over an extended period and serves as evidence for the relevant authorities when you apply for a care needs assessment.
  • If all relevant areas of life are consistently recorded, the chances of receiving the correct care classification increase.
  • An integrated care plan also helps structure daily care routines and provides emotional and mental relief for family caregivers.
  • A digital care diary provides greater transparency and structure and can be easily shared with others.
A care diary for family members creates structure and reduces mental stress
Caring for a family member at home is time-consuming and often emotionally draining. Between work, one’s own family, caregiving tasks, and necessary discussions with doctors and insurance providers, keeping a precise record of the care actually provided often falls by the wayside. As a result, in many cases, care needs are incorrectly assessed by the evaluating professionals, and important benefits from long-term care insurers are not approved. This leads to even more pressure, stress, and exhaustion for family caregivers. A structured, digital care journal helps break this dangerous cycle and ensure that eligible care benefits are received.
Whether individuals in need of care receive benefits from the long-term care insurance fund—and to what extent—depends on their individual support needs. These needs are assessed during a care evaluation conducted by an MD assessor. Based on this assessment, a care level is determined, which dictates the scope of approved benefits.
The problem: The in-home assessment often lasts only about an hour and is rarely sufficient to correctly assess needs. Especially if the person requiring care is having a “good day” on that particular day—for example, in cases of dementia—needs may be misjudged, with significant financial consequences.
Family caregivers often go into the assessment appointment with a vague sense of being overwhelmed, without being able to substantiate this feeling with concrete, verifiable information. As understandable as this may be given the emotional, mental, and often physical strain involved, the assessor evaluates based on a clear point system and considers only facts.
The specific structure of the assessment system varies by state and the responsible agency, but typically focuses on the same areas of daily life:
  1. Mobility: assesses physical mobility, changing positions in bed, getting up, sitting down, walking, and climbing stairs
  2. Cognitive and communicative abilities: takes into account temporal and spatial orientation, recognizing people, understanding risks, and carrying on conversations.
  3. Behaviors and psychological issues: takes into account nighttime restlessness, anxiety, and aggressive behavior.
  4. Self-care (i.e., basic care and personal hygiene): takes into account personal hygiene, nutrition, and toileting.
  5. Managing Illness- or Therapy-Related Requirements: Takes into account independent medication intake, wound care, doctor’s visits, and therapies.
  6. Organizing daily life and social interactions: considers whether the person plans their own daily routine, pursues hobbies, and maintains contact with others.
Instead of relying on vague statements, you should definitely back up your case with credible figures, which a care diary can provide: How often does your loved one need help getting out of bed? How many minutes does it take to help them wash or get dressed? How often do you need to assist them at night? Such detailed information is crucial for determining the care needs classification.
Assessor interviews a person in need of care: A care diary helps with preparation
The responsible agency is generally required by law to make the decision regarding the care level based on the assessment results. Without credible evidence of the actual care situation, the assessment appointment itself is the only basis for the decision. If you apply for a care level and immediately start keeping a care diary, you’ll ensure the necessary transparent documentation from the very beginning. In any case, you should start no later than two weeks before an assessment appointment in order to gather reliable data. This is the only way you can provide complete evidence of the areas where help is actually needed and the extent of that need.
Family caregivers should follow a few rules when keeping a log to document care needs:
  • Start early—no later than the day you submit your application.
  • Keep the care log for at least two weeks.
  • Record every instance of assistance provided promptly, preferably immediately afterward.
  • Note the approximate time spent in minutes.
  • Use consistent, clear terminology to describe how independently the person in need of care can still perform the task.
  • Also document intimate or uncomfortable situations, such as assistance with using the restroom, incontinence, or aggressive behavior.
  • Regardless of specific tasks, record the care recipient’s mood daily to provide the assessor with additional context.
When structuring your care log, it’s best to base it on the areas of daily life relevant to the assessment. Additionally, record household tasks—shopping, cooking, cleaning. This will give the assessor a more complete picture of the care situation, even if household tasks are not included in the actual assessment. Vital signs, a personal medication plan, or a nutrition log can also be useful components of the care log, depending on the situation.
For each activity, document whether your family member in need of care can perform it independently, mostly independently, mostly with assistance, or with full assistance. This grading system forms the basis for the assessors’ scoring and is important to prevent an overly low care classification from being approved.
Nighttime care interventions are most often omitted from the documentation. However, they are particularly significant for the assessment, as they indicate an increased need for care and limited independence. Therefore, be sure to consistently note how often assistance was needed at night, how long it lasted, and what kind of assistance it was—such as help using the restroom, calming the person during nighttime restlessness, or repositioning them in bed. Special challenges such as aggressive behavior, anxiety, or delusions should also be noted without fail, as they are evaluated in the “Behaviors and Mental Health Issues” module.
Both the person receiving care and their family members benefit from a structured care diary
The care plan should be distinguished from the care diary. While the care diary documents daily, step-by-step activities, a care plan provides the underlying structural framework. Unlike a care journal for family members, the care plan is created by licensed nursing professionals (sometimes with the involvement of physicians) and serves to guide care in a structured and goal-oriented manner. In addition to specifying the scope of care and care goals, this is where care measures are recorded, along with how often they should be performed and by whom—such as the family itself, an in-home care service, or a combination of both.
While a private care journal is voluntary and serves as documentation—not legally required—for assessors, doctors, and caregivers, the care plan is a mandatory, legally and professionally binding document that forms part of the official care documentation. A proven violation of the care plan may, under certain circumstances, result in serious consequences.
If you decide to document the care of your loved ones in a journal, you are not bound by any specific requirements. You’re free to choose between analog and digital options. However, you should be aware of the pros and cons of both formats.
A handwritten care log may seem straightforward at first—after all, a pen is always close at hand. Furthermore, there are no specific guidelines that a voluntary care journal for family members must follow, so you can in principle use any notebook or writing pad for this purpose. And finally, you’ll find numerous printable templates online. In daily practice, however, a traditional care journal often proves to be a problem.
A traditional care journal with a pen
Disadvantages of a paper care diary
  • The log gets misplaced or lost
  • Notes are quickly jotted down on random scraps of paper and not transferred later
  • On exhausting nights, family members are often too tired to write an entry
But it is precisely these details—which are then no longer recorded—that can be crucial for an assessment: How often did the patient need assistance at night? How long did personal care assistance take compared to other days? Are behavioral issues increasing in daily life? Such information only becomes meaningful when viewed over a longer period of time—and can rarely be accurately reconstructed retroactively.
With a digital, structured care log, you can easily avoid the drawbacks of a paper notebook without sacrificing flexibility or ease of use.
Benefits of a digital care log:
  • Digital care journals can often be flexibly customized
  • A centralized, structured database accessible at any time, rather than scattered notes.
  • A structured input form for quick, timely entries.
  • Automatic timestamps and change logs for maximum transparency with auditors.
  • Automatic calculation of cumulative time spent.
  • Shared access for multiple caregivers.
SeaTable is an AI no-code platform that lets you easily capture data, text, and documents and create structured applications. Customize the free care log template to suit your specific situation without any programming knowledge. You can also share your care log with others and update it collaboratively in real time. This way, other family members or an in-home care service can access the same up-to-date information simultaneously, rather than having to gather relevant details later via chat or email.
In the stressful day-to-day reality of caregiving, take advantage of the fact that SeaTable offers far more than just a simple table structure: The integrated automations with AI features simplify data processing. In the care diary app already included in the care journal template, you can enter new entries using a structured input form. The dashboard, which is always up to date, provides statistical analyses of care workload, vital signs, and moods.
Especially when it comes to a sensitive topic like private care documentation, strong data protection is crucial. With SeaTable Cloud, your data is securely stored on certified servers operated by the Swiss company Exoscale in Germany.
A care diary is a crucial tool for transparently documenting actual care needs and securing approval for the correct care level. Family caregivers who are already at their limit benefit especially from a digital solution like SeaTable, which makes documentation, analysis, and preparation for the next assessment appointment as easy as possible. Instead of getting lost in a sea of paperwork, structured, digital care journals provide transparency and generate traceable, analyzable data—saving caregivers both time and stress.
How long should you keep a care journal or care log?
Since care needs can vary from day to day, it is generally recommended that you keep a care log for at least two weeks. It is best to start keeping the care log on the very day you apply for care services.
What is the difference between a care plan and a care log?
A care plan outlines which care measures and medication administrations are scheduled over a specific period of time. In contrast, a care journal is used to document the actual daily care provided, regardless of whether these measures are included in the plan or not.
What are the benefits of a digital care journal?
With a digital care log, you can record care activities anytime, anywhere. It’s also easy to share with others, such as doctors, other family caregivers, or nursing staff. A paper care log, on the other hand, can easily get lost or forgotten in the course of daily life.
Should household chores also be included in the care log?
Yes, because even though domestic care is not directly factored into the assessment of the care level, assessors regularly ask about it. They need this information to get a complete picture and to develop an appropriate care plan. A care diary should therefore also include this information.
Can a care diary also help in appealing a denied care level application?
Yes, definitely. You can file an appeal against a denied application within the time limit specified by law. Thorough care documentation serves as an important benchmark for comparing the assessments made in the expert report.
TAGS: Everyday Life & Leisure
