You want to delete the first column of your table and wonder why you don’t see the necessary option in the column settings? No need to worry, this is intentional and has a specific reason, which we will explain to you in this article.
The special features of the first column
The fact that you cannot delete the first column of a table is due to the important function of this column. It is used in SeaTable to designate a record. For this reason, the first column of a table has several special features compared to the other columns, one of which is the property of not being able to be deleted.
You will learn all other peculiarities of the first column in the article The peculiarities of the first column.
What if I want to use a different first column?
If you want to use another column as the first column, you can customize the first column. Before doing so, you should duplicate the first column and simply copy and paste the data from the previous first column into the new column.
