With a large number of apps, it can become quite confusing on your homepage. Therefore, use SeaTable’s practical search function to find apps quickly.
Search for an app
  • Open the Homepage of SeaTable.
  • Use the key combination Ctrl + F or click in the search field in the top right corner.
  • Select whether you want to search your bases or your apps.
  • Now enter a part of the name of the app you are looking for in the search field – and SeaTable will provide you with all matching search results.
  • Click on the name in the hit list to open the desired app.
You will also see your last search results in a search history and can access these apps directly.
Last searched app
