For the optimal overview of the data in your table, SeaTable offers you views in which you can store your filters, sorts and groupings. You should give these views a meaningful name. Even afterwards, you can rename your views at any time.
Rename views
- Click the name of the current view.
- Hover the mouse over the view you want to rename.
- Three points become visible in the view line. Select them.
- Select the Rename view option.
- Delete the old name and type a new name.
- Confirm with Enter.
