Available with Enterprise
Sometimes you want to generate a few sample entries in a base. With this Python script you can generate from a few to many thousands of entries in no time.
This article will guide you through the different sections of the script so that you can understand how it works and customize it to your needs if necessary. You can find the full script at the end of this article.
1) Loading the modules
Every Python script starts with loading the Python modules used, where we will use base and context from the seatable_api class. You only need the module random in the second row if you want to generate random numbers.
import random
2) Authentication
The next two rows are necessary to establish the connection to the current base. After this authentication we can either read, delete or manipulate information via the base object.
base.auth()
3) Define new row contents
Now that we have access to the current table, we can define the records to create. The following code assumes that you have columns named Name, single, random, rating. If your columns are named differently, you will need to adjust the names accordingly.
# define the data for two new rows
rows_data = [
'Name': "I am new Row",
'single': "new",
'random': random.randint(0,100000000),
'rating': random.randint(0,5)
'Name': "I am second new row",
'single': "other value",
4) Write new rows
With the last code block the contents of the new rows were defined and stored in the variable rows_data, but not yet written to Base. We do this now with the following call.
# append the two rows
base.batch_append_rows(context.current_table, rows_data)
5) If you want more rows
Of course, you can also write more than two rows . You can do this either by simply defining more line contents or by using a loop to execute the write operation multiple times.
# execute batch append 10 times
for i in range(10):
The complete script
The complete script should be ready to run immediately on your end without any major adjustments. Change the four column names and the script should be able to create new rows in your table.
import random
base.auth()
# execute batch append multiple times
for i in range(10):
rows_data = [
'single': "new",
'single': "more than new",
The script can be started manually as well as via a button or via automation. You can learn more about this here .
