To get a better overview of your bases, you have the possibility to move individual bases into folders and group them there, for example, by topic or content. In total, there are two ways to move a base into a folder:
- Drag and drop a base into a folder
- Move a base to a folder via context menu
- Switch to the SeaTable home page.
- Select the base you want and drag and drop it into any folder.
- Click the three dots to the right of any base.
- Click Move to Folder.
- Select a folder of the group to which you want to move the base.
- Confirm with Submit.
Restriction
A base can only be moved to a folder that belongs to the same group as the base itself. If you want to move a base to a folder of another group, you must first copy the corresponding base to the desired group.
