At first glance, SeaTable looks like a spreadsheet, but it is a relational database. This means: The tables in SeaTable are not isolated, but can be related to each other using link columns. This works both with records within a table and across multiple tables.
Since linking records in SeaTable is done with special columns, you will find all further explanations about the link column in the article of the same name.
For the special features of links within a table you will find a separate guide.
For an introduction to the technical background, we recommend the article on relational databases.
