Use the relational database functions of SeaTable by linking information from different tables. To do this, use the Link to other records column type.
Create link between two tables
  1. Create a new column and select the column type Link to other records.
  2. Give the column a name.
  3. Under Select table for linking, select the table whose records you want to link to the current table.
  4. Click Submit.
  5. The content of the new column is still empty. To fill it, you can link existing records or add new rows .
As soon as tables are linked, you can call up the information of the linked records via the link dialog. To do this, click on the double arrow symbol in a cell of the link column or double-click. The linked records are listed in the link dialog that opens. Click on an record to view the row details in an additional window.
Row detail view for linked records
Link existing records
  1. Click in a cell of the link column and then on the plus icon that appeared.
  2. Now the available rows of the linked table are listed. Select the row(s) you want to link to the row of your current table.
  3. In the link column, each row is immediately displayed as a linked record.
Using the integrated search function in the link dialog, you can search the records of the linked table to quickly find the desired row .
You can even add a new row to a linked table via the link dialog without having to switch to this table. Subsequently, the row is added to the linked table among the existing records and displayed as a linked record in the link column of the opened table.
  1. Double-click on the cell of a link column or click on the blue double arrow icon to open the link dialog.
Double-click in a link column
  1. Click row to add.
Click to add row
  1. In the window that opens, fill in the various table columns.
Filling in the table columns
  1. Click Submit to create the new row .
Click submit
  1. The new row is automatically added to the linked table and displayed in the currently opened table as a linked record in the link column.
Edit existing records of a linked table
  1. Click in a cell of the link column.
  2. Click on the linked record you want to edit.
  3. The row details open. Make the desired changes there.
  4. Close the window to save the changes.
You can remove records linked in a link column with just a few clicks. To do this, simply open the link dialog of the corresponding link column and click on the X symbol to the right of the desired record.
Remove links
A link column allows you to make and change various settings very easily. To do this, click the triangular drop-down icon of the link column in the table header and then click Settings.
Open settings of a link column
In the drop-down menu you can first select the column of the linked table whose entries are to be displayed in the link column.
Selection of the linked column from the linked table
By activating the corresponding slider you can limit the linking to a maximum of one row. If this setting is active, only one linked record can be added in each cell of the link column.
Restrict links
If you have already added a linked record to a cell, the options to add more records are no longer displayed.
If the link is limited to a maximum of one row , the options for adding links in the link dialog are no longer available for selection once a link has been added
This setting can be useful, for example, if an invoice is to be linked to the corresponding purchase order from another table - i.e. if the linked records form logical pairs. In this case, adding more links could lead to confusion and negatively affect work processes.
By activating this setting you can restrict links to one view of the linked table. To do this, you specify a previously defined view of the linked table. In the link column, you can then link only the records of this view. Linking records from other views is then no longer possible.
Restrict links to one view
This setting is especially useful for filtered views this setting can be helpful if you want to specifically link individual records in your tables.
In the settings of a link column you can also prevent the linking of existing records by activating a corresponding slider. If the slider is activated, the corresponding link column supports only the addition of new rows or records.
Existing records in the linked table can then no longer be linked in the column. records that have already been linked in the column, however, remain unaffected by the setting.
Setting to prevent linking of existing records
The link dialog of a link column also provides you with various view options.
To have all linked records at a glance, you can adjust the size of the link dialog window. To do this, simply move the mouse over one of the outer borders until the cursor turns into a double arrow, and drag the border in the desired direction while holding down the mouse button.
Adjust window size of the link dialog
To fit more column records of the linked rows into the window, you can also adjust the width of the displayed columns in the link dialog. To do this, move the mouse over the area between two column names until the cursor turns into a double arrow, and drag the invisible boundary line to the left or right while holding down the mouse button until you reach the desired column width.
Adjust column width
To make the link dialog even clearer, you can hide any number of columns of the linked records by clicking on the eye symbol. A window opens in which you can (de)activate the individual columns with sliders. Accordingly, the columns are hidden or displayed in the overview of the linked records.
Hiding certain columns in the linked records view in the dialog box of a linked column
You can sort the linked records in the link dialog by clicking on the arrow icons. Use this function, for example, to display linked records in alphabetical order based on a text column or to sort them by another column.
Sorting records in the link dialog of a link column
I can't find this column type. Can't I create a link?
The Link column is available in every SeaTable subscription. However, you are probably trying to change the column type of an existing column. When changing the column type, the Link to other records column type is actually not available to you. Instead, create a new column and you will be offered the column type you want.
