The grouping function allows you to combine table records into groupings and calculate simple descriptive statistics such as the number of elements or totals and averages of number columns. The grouping is carried out using identical values in the column selected for the grouping.
Grouping records in a view
  1. Create a new view or select the view in which you want to group.
  2. Click the Group option in the view options above the table.
  3. Go to Add group.
  4. In the empty field, select the column by which you want to group.
  5. In the second field, decide whether the grouping should be listed in ascending or descending order.
The grouping is carried out in real time, i.e. the data records are grouped before the window is closed. This allows you to see immediately whether you have achieved the desired result and make any necessary adjustments.
You can group by adding further groupings according to up to three criteria at the same time. This creates multiple levels or subgroups within the groupings.
Grouping records in a view with two criteria
To adjust the grouping, open the window again by clicking on the button in the view settings. Just as when adding the grouping rule, you can now customize the rule. You can also change the hierarchy of the grouping rules by holding down the left mouse button on the six-point grip area and dragging the rule to the desired position.
SeaTable supports grouping by all column types except the column types Formatted Text, File, Image, Auto Number, Button, and Digital Signature.
The grouping is based on the following ordering principles:
  • Text, E-mail, URL, Phone number: alphabetical or alphanumeric
  • Number, duration, rating: numerical
  • Date, Created, Last modified: chronological
  • Single and multiple select: according to the order of the options
  • Collaborator, Creator, Last modifier: alphabetical
  • Checkbox: dichotomous
  • Formula: depending on the data type of the result
  • Link: depending on the data type of the referenced column
All rows with empty cells in the grouping column are summarized at the bottom of the view in a separate group called (Empty).
Each group has a header in which both the criterion of the group and the number of records within the group are listed.
The group header
In the case of number columns, you also have the option of displaying various relationships between the entries:
  • Total
  • Average
  • Median
  • Minimum
  • Maximum
  • No calculation
Click the triangular drop-down icon in front of the column headline to select the respective option.
Group header number column
Using the triangular drop-down icon on the left of the group header, you can individually reduce and expand the display of records in each individual group.
Grouping records of a view _reduce and expand
The Reduce All or Expand All options allow you to collapse and expand the display of records in all groups with one click.
Here you will find the Reduce All option:
Reduce all
Reduce the display with the option enabled:
Example for all reduce for groupings
Here you will find the Expand All option:
Extend grouping option all
Expand the display with the option enabled:
Example for all expand at groupings
You can assign individual records to new groups by dragging and dropping them. The criterion on which the group is based is adjusted when the entry is moved.
Grouping records Drag and drop
Of course, you can delete groupings at any time by clicking on the x symbol in front of the respective grouping.
Delete grouping
