You can use the data processing function to perform various operations across a column. Compare and copy is an operation with which you can copy the values of a column from one table to the column of another table, provided that a certain comparison value is identical in both data records.
Create a data processing action
  1. Open any table and click the three dots in the view options.
  2. Click Data Processing, and then click Add Data Processing Operation.
  3. Give the operation a name and select Compare and Copy.
Naming the data processing action and selecting the operation type
  1. Define from which table the data originates and to which table you want to copy the data.
  2. Set one or more conditions in which two columns of the compared tables must have a value identical for the operation to be performed.
  3. Select one or more source columns from which values will be copied to result columns that you also define, provided that the match conditions you specify are met.
Definition of the data processing action
  1. Click Save to save the action and execute it later, or Execute to execute the action directly.
On the first successful execution, a small Green hook.
If the data processing action is successfully executed for the first time, a green tick appears
A concrete use case for this data processing operation could occur, for example, if you maintain the employee data of your team members in one table and want to create the tasks of your team that still need to be completed in a new table. By adding a column with the names of the employees responsible for the respective tasks, you want to create a match between the tables.
Subsequently, you want certain data of the employees, which are already available in the employee table, to be copied to the task table. For example, you might also need the e-mail address there to be able to contact the responsible person directly.
To implement this data processing operation, you need two tables in the same base. In the first table, the employee data is maintained, which includes, among other things, the employees’ e-mail addresses.
Example table for maintenance of personal data of mtployees
In the second table you enter the open tasks, for which the respective responsible employee is entered in another column. In addition, you create a new column of the type e-mail, into which the e-mail addresses are to be copied later.
Target table including the result column before the data processing action is executed.
To create the data processing operation, follow the steps described above. For the specific use case, select as a condition that the name of an employee in the name column in the employees table must match the name in the responsible column in the open tasks table. This step is essential so that the correct data of the corresponding employees is copied during the data processing operation.
Definition of the match condition for the data processing action.
In the next step, you can select any number of source columns from the employees table, whose contents will be copied to the selected result columns of the open tasks table when the operation is executed and the just defined match condition is true.
Selection of columns from the source table whose contents will be copied to the target table if the match condition is true.
When the operation is successfully executed, the employees and open tasks tables are checked for matches in the defined name and responsible columns. If the names in the columns of both tables match, the e-mail address of the corresponding employee is automatically copied from the defined column e-mail to the result column contact.
Content copied to the target table after the data processing action has been triggered.
The following column types cannot be copied using the Compare and copy operation and are therefore not available when defining the source and result columns.
