Ce script traite les enregistrements de temps et génère des statistiques de présence quotidiennes. Pour chaque employé et jour, il détermine l’entrée la plus précoce (arrivée) et la plus tardive (départ) et écrit les résultats dans une table de statistiques séparée.
Prerequisites
You need two tables:
- Time records: Contains columns
Name,Date, andTimewith the raw clocking data. - Statistics: Contains columns
Name,Date,Clock in, andClock outfor the results.
The complete script
base.auth()
TIME_RECORDS_TABLE = "Time records"
STATISTICS_TABLE = "Statistics"
# Clear statistics table to avoid duplicates on re-run
for row in base.list_rows(STATISTICS_TABLE):
base.delete_row(STATISTICS_TABLE, row['_id'])
# Group time records by date and name
rows = base.list_rows(TIME_RECORDS_TABLE)
groups = {}
for row in rows:
name = row.get('Name', '')
date = row.get('Date', '')
time = row.get('Time', '')
if not name or not date or not time:
continue
key = f"{date}_{name}"
if key not in groups:
groups[key] = {'name': name, 'date': date, 'times': []}
groups[key]['times'].append(time)
for key, group in groups.items():
times = sorted(group['times'])
clock_in = times[0]
clock_out = times[-1]
base.append_row(STATISTICS_TABLE, {
'Name': group['name'],
'Date': group['date'],
'Clock in': clock_in,
'Clock out': clock_out
print(f"{group['name']} ({group['date']}): {clock_in} - {clock_out}")
print(f"---
{len(groups)} entries created.")
Adjust the table and column names to match your setup. The script always appends new rows – if you run it multiple times, clear the statistics table first to avoid duplicates.
