Ce script fusionne plusieurs fichiers PDF stockés dans une colonne de fichiers en un seul document PDF et enregistre le résultat dans la ligne.
The complete script
import pdfmerge
from io import BytesIO
import os
base.auth()
TABLE_NAME = "Documents"
FILES_COLUMN = "PDF Files"
RESULT_COLUMN = "Merged PDF"
for row in rows:
files = row.get(FILES_COLUMN, [])
if not files or len(files) < 2:
continue
if row.get(RESULT_COLUMN):
continue
# Download all PDFs
tmp_files = []
for i, f in enumerate(files):
url = f if isinstance(f, str) else f.get('url', '')
content = base.download_file(url)
tmp_path = f"/tmp/pdf_{i}.pdf"
with open(tmp_path, 'wb') as fh:
fh.write(content)
tmp_files.append(tmp_path)
# Merge
output_path = "/tmp/merged.pdf"
pdfmerge.pdfmerge(tmp_files, output_path)
# Upload
with open(output_path, 'rb') as fh:
info = base.upload_bytes_file("merged.pdf", fh.read())
base.update_row(TABLE_NAME, row['_id'], {RESULT_COLUMN: [info.get('url')]})
# Cleanup
for f in tmp_files:
os.remove(f)
os.remove(output_path)
print("PDFs merged.")
The script skips rows that already have a merged PDF or have fewer than two files. Adjust the column names to match your table structure.
