Many companies start out with Excel or Microsoft Access as their database structure to manage their data and organize internal processes. This usually works well at first, but as the amount of data grows, it becomes increasingly difficult to keep track of everything.
Often this is because the database was not properly planned from the start. If you create tables without a clear database structure, do without unique IDs or fail to link related data, duplicate and contradictory information quickly piles up. This makes day-to-day work tedious and complicates later adjustments. In the worst case, you have to fundamentally rebuild your database or even switch to a new system.
A well-thought-out database schema gives you a solid foundation for your data management. You determine which information you store in which tables and how the individual records relate to each other. This way you keep track of everything and can still easily expand your database when your requirements change. No-code databases in particular offer you flexible options for this without requiring extensive programming skills.
In this article, you will learn which database models exist, what to look out for when planning your database schema and which five typical mistakes you can avoid. We will also use a practical example to show you how to structure and link your data in a meaningful way.
The 4 classic types of database models #
Before you plan your database, you should know the different database models. They differ in how they store information and connect it. Which model is right for you depends on which data you manage and how you want to use it.
The relational database model #
The relational database model is particularly widespread in companies. It organizes information in tables consisting of rows and columns. Each row contains a record, while the columns describe the individual attributes. Unique keys allow you to link records from different tables.
One example is a customer database. You store customer data in one table and keep projects in another table. A shared customer ID assigns each project to the right customer. This way, you don’t have to enter customer information again for every project.
The hierarchical database model #
The hierarchical model organizes data like a tree. A parent record can contain several child records. This creates a clear parent-child structure between the records.
This is suitable, for example, for organization charts or directories with a fixed hierarchy. However, as soon as a record needs to be assigned to several parent entries, this model reaches its limits.
The network database model #
The network model allows more complex connections than the hierarchical model. A record can be linked to several other records. This also makes it possible to represent relationships in which several entries are related to each other.
This is particularly helpful when data has many different connections. However, the database structure can quickly become complex and is therefore harder to keep track of and maintain.
The object-oriented database model #
The object-oriented model stores information as objects. In addition to data, these can also contain properties and functions. The model is particularly suitable for applications that work with complex data structures, such as in engineering or simulations.
For many typical business applications, the relational database model is a good foundation. You can use it to organize customers, projects, tasks or employees in separate tables and connect them through relationships. This keeps individual pieces of information clear and avoids unnecessary duplication.
No-code databases like SeaTable take up this principle and make it usable without extensive programming skills. You create tables and fields visually and link related records directly to each other. No-code is not a database model of its own, but an approach that lets you create and adapt database applications more easily.
Why a well-thought-out database structure pays off in the long run #
A well-thought-out database structure makes your daily work easier and helps you develop your database further in the long term. Above all, you benefit from these advantages:
- Fewer data silos and redundancies: You bring related information together centrally, avoid duplicate entries and ensure that all teams work with a consistent data set.
- Less effort for adjustments: You add tables, fields and links in a targeted manner instead of having to fundamentally rebuild your database with every new requirement.
- More scalability: You take growing data volumes, additional users and new business processes into account early on. This way your database grows with the requirements of your company.
- Better data quality and maintainability: Unique IDs, clear relationships and a comprehensible structure help you avoid errors and maintain your data reliably.
How to properly plan the structure of a database #
Before you create your database, you should think about how it is built. A clear database structure helps you organize information logically, avoid duplicate data and implement later extensions more easily. A well-thought-out database schema gives you the right foundation for this.
Pay attention to the following points when planning:
Step 1: Define data and tables
Step 2: Define fields and data types
Step 3: Assign unique primary keys
Step 4: Link tables via foreign keys
Step 5: Consider relationships and normalization
Step 6: Visualize the database structure
The five most common mistakes when building a database #
Even if you know the basics of a database, mistakes can occur during planning and implementation. They are often only noticed when the data volume grows or several people work with the database. You should therefore avoid these five problems from the start.
1. Lack of a logical structure #
If you create new tables spontaneously without considering the overall database design, you quickly end up with a confusing data set. Information ends up in the wrong tables or appears multiple times. This makes maintenance difficult and later adjustments time-consuming.
How to avoid this mistake: Think in advance about which information you want to capture and how it belongs together. Divide your data into logically structured tables and make sure to use consistent naming.
2. Missing unique IDs #
Without unique identifiers, it is difficult to distinguish individual records. This becomes particularly problematic when several customers have the same name or information changes over time. It also makes linking tables more difficult.
How to avoid this mistake: Assign a unique primary key to each record. A sequential number or an alphanumeric ID works well for this. You can then use foreign keys to establish relationships with other tables.
3. Storing data multiple times instead of linking it #
If you store the same information in several tables, unnecessary data redundancies arise. If, for example, a customer address changes, you have to update it everywhere. If you forget an entry, your database contains contradictory information.
How to avoid this mistake: Store each record only once if possible and use links to reuse it in other tables. This way you maintain information centrally and keep your data consistent.
4. Modeling relationships between tables incorrectly #
It is not enough to link tables with each other. You also have to define how the data is actually related. Without clearly defined relationships, incorrect assignments and data structures that are hard to follow arise. The differences between 1:N and N:M relationships are particularly important here.
How to avoid this mistake: Define the relationships as early as the planning stage of your database schema. Use an ER diagram to visualize the links between the tables. This lets you recognize early on whether your database structure is logical.
5. Not designing the database for future growth #
A database that is sufficient today for a few users and manageable amounts of data can quickly reach its limits as requirements increase. If you don’t take additional users, new processes or larger data volumes into account, you risk time-consuming adjustments and costly system changes.
How to avoid this mistake: Plan your database from the start so that you can add more tables, fields and users later. Make sure your database structure is flexible and check whether a scalable cloud or no-code database better suits your long-term requirements.
Practical example: Database design using a project database #
How to plan your database structure is best understood with a concrete database design example. Imagine you want to manage projects centrally while keeping track of customers, employees, tasks and project progress. Instead of collecting all information in a single table, you divide your data into several linked tables.
Splitting tables sensibly #
For a simple project database, you need the following tables, for example:
- Customers with customer name, contact person, contact details and customer ID
- Projects with project title, start date, status, responsible customer and project ID
- Tasks with task description, deadline, status and associated project ID
- Employees with name, department, contact details and employee ID
Each table covers a separate area. This prevents you from having to re-enter customer information for each project or from tasks and employees getting lost in a confusing overall table.
Linking records with each other #
So that your database does not consist of isolated tables, you link the individual records with each other. A customer can have several projects, for example. This creates a 1:N relationship between customers and projects. A project in turn comprises several tasks, so there is also a 1:N relationship here. If several employees work on different projects, however, an N:M relationship arises. An employee can be assigned to several projects and a project can include several employees. Such relationships can be mapped via an additional junction table.
Why this database design makes sense #
With this structure, you store information only once and access it via links when needed. If, for example, a customer’s phone number changes, you update the record in the customer table instead of adjusting the information in several projects.
You can also expand your database at any time. Add a table for budgets, documents or project teams, for example, without having to completely change the existing database design.
With a no-code database in particular, you can display these tables and links visually. This way you can see directly how your data is connected and adapt the structure to new requirements without having to rebuild the database from scratch.
SeaTable vs. MS Access: When is it worth switching? #
Microsoft Access is well suited for building smaller database applications and mapping internal processes. Especially if you already work with Microsoft Office, you can quickly create tables, forms and queries. However, as requirements, users and process complexity increase, further development becomes more and more time-consuming.
Modern no-code databases like SeaTable offer you a more flexible approach. You create tables, link records and use the visualization of the database structure to recognize connections and adapt your database flexibly – without SQL queries or extensive programming.
| SeaTable | MS Access | |
| Database model | No-code database with relational data structures and link columns | Relational database with tables, primary and foreign keys |
| Database design | Visual creation of tables and columns via a spreadsheet-like user interface | Creation of tables and fields via datasheet and design view |
| Linking tables | Direct linking of records via special link columns | Relationships via primary and foreign keys |
| Modeling relationships | Linking of single or multiple records; N:M relationships possible without an additional junction table | 1:1 and 1:N relationships; N:M relationships via junction tables |
| Visualization of the database schema | Graphical representation of the table structure and its links via the table relationships plugin | Graphical representation of tables and relationships in the Relationships window |
| Adapting the database structure | Adding and editing tables, column types and links directly via the user interface | Adapting tables, fields and relationships via the design view and the Relationships window |
| Programming skills | Basic database design without programming; rule-based automations and optional scripts | Basic functions usable without programming; advanced functions via macros, SQL and VBA |
| Scalability | By default up to 100,000 active records per base; additional records via big data storage with functional limitations | Maximum of 2 GB per Access database file; expansion possible via external database servers such as SQL Server |
| Collaboration | Real-time collaborative editing of data in the browser | Multi-user operation via network shares, split databases or external database servers |
| Permission management | Individual permissions at base, view, table and column level, depending on the plan | File-based; granular user permissions, for example via an external database server |
| Operating model | Cloud solution or self-hosting on your own server infrastructure | Local desktop database, network solution or connection to external database servers |
| Data protection | GDPR-compliant | GDPR-compliant |
If you reach the limits of your Access database structure, make adjustments more frequently or want to make your database accessible to several employees, switching to a modern database platform can be worthwhile.
With SeaTable, you can rebuild your existing database structure, link tables with each other and gradually expand processes. You keep control over your data and can adapt your applications to new requirements without having to plan time-consuming development work for every change. Especially for CRM systems, project management, resource planning or individual process management, a no-code approach offers a way to design database applications more flexibly and develop them further in the long term.
How to maintain your database structure in the long term #
A well-planned database structure is only helpful in the long term if you maintain it regularly. New requirements, additional tables and changed processes can make your database design more complex over time. To keep your data consistent and comprehensible, you should observe a few points.
- Document the database schema and relations: Record which tables exist, which data fields they contain and how the tables are linked. Comprehensible documentation makes later adjustments easier for you and your team.
- Name tables and data fields consistently: Use clear and consistent names. Uniform naming conventions help you quickly identify tables and fields and avoid misunderstandings when maintaining data.
- Check data quality regularly: Check your data for duplicate entries, missing information, outdated information and incorrect links. This ensures that your database continues to deliver reliable information in the long term.
- Document and test changes: When you extend your database schema or adjust existing relations, you should document the changes in a comprehensible way and test them before productive use. This helps you avoid errors that could affect existing processes.
- Define permissions and responsibilities: Define who may edit data, change tables or create new fields. Clear responsibilities reduce uncontrolled changes and make collaboration easier.
- Develop the database structure visually: Use ER diagrams or visual data modeling to keep track of your tables and relationships. No-code platforms also let you implement changes directly and make recurring processes more efficient through automations.
Conclusion: Planning for the future with a scalable database schema #
A well-thought-out database design determines how reliably and flexibly you can manage your data in the long term. If you structure tables logically, assign unique IDs and model relationships sensibly, you avoid redundant data, make maintenance easier and create a foundation for future extensions.
So don’t just plan your database schema for current requirements, but also take possible changes and growth into account. With a no-code database like SeaTable, you can design, visualize and adapt tables and links flexibly without extensive programming. This keeps your database clear and lets it grow with your company.
FAQs – Frequently asked questions #
What types of databases are there and which one is suitable for companies?
What are the four classic database models?
The four classic database models include the relational, hierarchical, network and object-oriented models. They differ in how data is organized and linked.
- Relational model with tables and links
- Hierarchical model with tree structures
- Network model with complex links
- Object-oriented model with objects and properties
Why does a traditional Access database structure reach its limits today?
Microsoft Access is well suited for smaller database applications and manageable processes. However, when more users access the database at the same time, data volumes grow or applications become more complex, the effort for maintenance and further development increases. Companies then reach the limits of an Access database structure above all in the following areas:
- Scalability with growing data volumes
- Collaboration across different locations
- Adaptation to more complex business processes
- Maintenance and further development of existing applications
What are practical examples of modern databases in everyday business?
Modern databases support companies in centrally managing and linking different information.
- CRM databases for customers and sales processes
- Project databases for tasks, resources and progress
- Personnel and applicant databases for HR processes
- Inventory and product databases for stock and supply chains
How do I export an SQL database or transfer data to a new system?
You can export an SQL database by backing up the data it contains and, if necessary, the table structure via the export function of your database system. To migrate to another system, you should follow these steps:
- Export tables and records
- Check the data structure and relationships
- Adjust data types and field mappings
- Import the data into the target system and then validate it
