Этот скрипт обрабатывает записи о рабочем времени и формирует ежедневную статистику посещаемости. Для каждого сотрудника и дня он определяет самый ранний приход и самый поздний уход и записывает результаты в отдельную таблицу статистики.
Prerequisites
You need two tables:
- Time records: Contains columns
Name,Date, andTimewith the raw clocking data. - Statistics: Contains columns
Name,Date,Clock in, andClock outfor the results.
The complete script
base.auth()
TIME_RECORDS_TABLE = "Time records"
STATISTICS_TABLE = "Statistics"
# Clear statistics table to avoid duplicates on re-run
for row in base.list_rows(STATISTICS_TABLE):
base.delete_row(STATISTICS_TABLE, row['_id'])
# Group time records by date and name
rows = base.list_rows(TIME_RECORDS_TABLE)
groups = {}
for row in rows:
name = row.get('Name', '')
date = row.get('Date', '')
time = row.get('Time', '')
if not name or not date or not time:
continue
key = f"{date}_{name}"
if key not in groups:
groups[key] = {'name': name, 'date': date, 'times': []}
groups[key]['times'].append(time)
for key, group in groups.items():
times = sorted(group['times'])
clock_in = times[0]
clock_out = times[-1]
base.append_row(STATISTICS_TABLE, {
'Name': group['name'],
'Date': group['date'],
'Clock in': clock_in,
'Clock out': clock_out
print(f"{group['name']} ({group['date']}): {clock_in} - {clock_out}")
print(f"---
{len(groups)} entries created.")
Adjust the table and column names to match your setup. The script always appends new rows – if you run it multiple times, clear the statistics table first to avoid duplicates.
