Этот скрипт объединяет несколько PDF-файлов из столбца файлов в один PDF-документ и сохраняет результат обратно в строку.
import pdfmerge
from io import BytesIO
import os
base.auth()
TABLE_NAME = "Documents"
FILES_COLUMN = "PDF Files"
RESULT_COLUMN = "Merged PDF"
for row in rows:
    files = row.get(FILES_COLUMN, [])
    if not files or len(files) < 2:
        continue
    if row.get(RESULT_COLUMN):
        continue
    # Download all PDFs
    tmp_files = []
    for i, f in enumerate(files):
        url = f if isinstance(f, str) else f.get('url', '')
        content = base.download_file(url)
        tmp_path = f"/tmp/pdf_{i}.pdf"
        with open(tmp_path, 'wb') as fh:
            fh.write(content)
        tmp_files.append(tmp_path)
    # Merge
    output_path = "/tmp/merged.pdf"
    pdfmerge.pdfmerge(tmp_files, output_path)
    # Upload
    with open(output_path, 'rb') as fh:
        info = base.upload_bytes_file("merged.pdf", fh.read())
    base.update_row(TABLE_NAME, row['_id'], {RESULT_COLUMN: [info.get('url')]})
    # Cleanup
    for f in tmp_files:
        os.remove(f)
    os.remove(output_path)
print("PDFs merged.")
The script skips rows that already have a merged PDF or have fewer than two files. Adjust the column names to match your table structure.
