Этот скрипт вычисляет накопленные итоги по строкам таблицы. Для каждой строки он прибавляет текущее значение к сумме всех предыдущих строк и записывает результат в столбец “Accumulated”. Автоматически обрабатывает группированные и негруппированные представления.
The complete script
base.auth()
TABLE_NAME = "Table1"
VIEW_NAME = "Default View"
COLUMN_CURRENT = "Value"
COLUMN_ACCUMULATED = "Accumulated"
# Look up view and table metadata
table = None
view = None
for t in metadata['tables']:
if t['name'] == TABLE_NAME:
table = t
for v in t['views']:
if v['name'] == VIEW_NAME:
view = v
break
break
if not table:
print(f"Table '{TABLE_NAME}' not found.")
elif not view:
print(f"View '{VIEW_NAME}' not found.")
else:
rows = base.list_rows(TABLE_NAME, view_name=VIEW_NAME)
# Build a mapping from column key to column name
col_key_to_name = {col['key']: col['name'] for col in table['columns']}
updated = 0
if view.get('groupbys') and len(view['groupbys']) > 0:
# Grouped view: reset accumulated value per group
group_col_key = view['groupbys'][0]['column_key']
group_col_name = col_key_to_name.get(group_col_key, '')
groups = {}
for row in rows:
group_val = row.get(group_col_name)
if not group_val:
continue
group_val = str(group_val)
if group_val not in groups:
groups[group_val] = []
groups[group_val].append(row)
for group_val, group_rows in groups.items():
accumulated = 0
for row in group_rows:
value = row.get(COLUMN_CURRENT, 0) or 0
accumulated += value
base.update_row(TABLE_NAME, row['_id'], {COLUMN_ACCUMULATED: accumulated})
updated += 1
else:
# Non-grouped view
accumulated = 0
for row in rows:
updated += 1
print(f"{updated} rows updated.")
Adjust the four variables at the top to match your table. If your view is grouped, the accumulated value resets for each group.
