Available with Enterprise
You can only create new rows in normal SeaTable views. You must then manually move the desired rows to the big data storage.
rows move to the big data store
  1. Click the three dots in the view options.
  2. Select the Archive View option.
  3. Confirm the move of all visible rows to the big data storage.
The rows are then transferred to the big data storage. As a result, they are no longer visible in the normal view. Create a big data view to display data in the big data storage.
rowsstored in the Big Data store have a small gray triangle in the numbering column .
Good to know:
  • In a normal view , you will not see rows from the big data storage.
  • All rows can be displayed in a big data view , regardless of where they are currently stored.
You can find out how to retrieve entries from the big data storage in this article .
