At the latest when your base has gradually filled up with various tables, it is time to think about a sensible order for the tables in your base. Move thematically related tables next to each other and place the most important tables at the top. You will see: Thanks to drag-and-drop, moving tables is child’s play.
You can arrange your tables horizontally in the base header as you wish.
Move tables in the base header
  1. Move your mouse to the tab of the table you want to move.
  2. Hold down the left mouse button and drag and drop the desired table to any position in the base header.
In bases with a large number of tables, it is more convenient to move the tables vertically using the drop-down list.
Move tables via the drop-down menu
  1. Click on the drop-down arrow to the right of the last visible table.
  2. Move your mouse to the list position of the table you want to move.
  3. Hold down the left mouse button and drag and drop the table to the desired position.
