Available with Plus Enterprise
To prevent unwanted changes to rows, you can lock rows. This can be useful, for example, if more than one person is working in a table. The locking can either be done manually by you or automatically by an automation .
To lock a row
- Open any table in which you want to set a row want to lock.
- Right-click on the row to open the drop-down menu.
- Select the Lock row option.
As soon as a row is locked, a small red triangle appears in the numbering column.
Unlock rows
Just as you lock a row , you can also unlock it. To do this, follow the click instructions described above and select the Unlock row option.
Lock rows with the help of automation
Available with Enterprise
In SeaTable you can create automation rules to automatically lock rows when they meet certain conditions.
This is very useful if you want to lock many rows at once or always want to prevent a row from being processed further from a certain point in time (e.g. when a process has been completed).
You can find out more about this in the article Locking rows via automation .
